Brendons M35 build
Thought I'd create a mini build thread on my progress with my first foray into Nissan wagon life and also a place to ask questions/path to follow.
I bought the car with f**ked coil packs so I picked it up cheap off some Indian guy. Put a new set of coil packs in and all was sweet for the next 6 months . . .
https://imageshack.com/i/pnV0vOWcj
https://imageshack.com/i/pltD8QHij
https://imageshack.com/i/popQVxMsj
I noticed an oil leak from the passenger side that was slowly getting worse and traced it back to the oil feed line. Ah well no biggy, just an easy fix or so I thought! Having not worked on a VQ before, it wasn't until later on I discovered you can't get the line off without pulling the whole turbo :down: Since the car wasn't far off 200k and the turbo had begun the Dyson whine song, I frantically searched for a new turbo. Scotty to the rescue with a Billet Intense he had spare that got to me in 4 days.
In the mean time while the car was off the road I set about fabbing up a 3" bellmouth dump pipe.
Then followed it up with a 3"-2.5" intake pipe. (Still need to weld on BOV return bung)
And this weekend just gone I fabbed up a 3" catless exhaust system to finish it all off. I picked up 7psi of boost without touching a thing, so it's stuck on 21psi with standard injectors and pump. I've hit up Christian to see if it's possible to run the car safely at this level on 98 with his flash tune, otherwise I will probably put a hi-flow cat in to drop the boost a little.
I've got a few other things in the works but all in due time!:10_wink:
Edited by Sack87
Pics not working
  • Like 8
https://www.sau.com.au/forums/topic/471232-brendons-m35-build/
Productive day trying out my my new pipe bender. Made up a rear subframe brace to help reduce some flex because the factory welds back there horrid. :2_grimacing:
I plan on making a few more of these up, so watch this space if you're interested in one:1311_thumbsup_tone2:
  • Like 5
You can buy a brand new one from Nissan for around $100 but your looks solid and nice welding.
Replaced the headlight globes last weekend with some LED Nighteye ones off eBay.
Fixed the dodgy wiring job obviously done by the compliance shop and also fixed the issue with the passenger side globe constantly dropping out. The H1 globes earth through the clip into the light body but the clip had been bent and contact was poor. The LED globes have earth through the harness, so crimped on some plugs and walla!
They just fit in behind the cover luckily and beam spread is awesome. High beams are like having spotlights fitted.
  • 5 weeks later...
  • 3 weeks later...
Made the mounts for the FMIC. They just touch the grill mounting tabs on the front bumper by about 3mm so I'll have to dremel a little bit off but it won't be noticeable.
Also did the hot side piping and some of the cold side but forgot to grab a 3" 45 degree bend. I plan on making it 3" to the throttle body eventually as I need to run a 3" to 2.5" 45 degree reducer currently.
  • Like 3
  • 5 weeks later...
Made up the rear subframe front brace to finish off the trio. I'll make a few more up as usual and will look into gearbox bracing next.
Also got around to fabbing up the 3" IC piping that goes to the throttle body so it's full 3" from the FMIC. Just need to finish tidying up around where I silver soldered the nipples in and the BOV flange needs facing.
  • Like 6
Finished off fitting the FMIC and wrapped the 3" throttle piping in heat reflective tape.
Next on the list is to make up a few little brackets to relocate the sensor and solenoid and clean up the hosing.
  • Like 3
  • 5 weeks later...
The plastic under body engine guard was looking pretty poor so I decided to make a new one up out some ali sheet. I made up a template and cut out a simplified version of the factory one. But what do you do when you don't have a sheet metal bender?...
You make your own one; and it works f**king mint :happy: It's a heavy duty sucker that will do up to 3mm sheet and stores away nicely with removable handles. I still need to add some vertical supports to the angle that bolts down on the sheet and drill some holes to mount it to the bench instead of using clamps.
So with that side project made, I bent up the sheet and you end up with a nice shiny undertray.
I'm also working on something else too as you can see but it's still in the "refinement" stage.:1311_thumbsup_tone2:
  • Like 3
Made up a smaller reo bar so I can fit a FMIC in without having to change condenser fan and also make more room to fit in a trans cooler.
Hey, any chance I can get the dimensions of that front bar? The length. I was considering doing the same type of thing to mine because of my fmic!
  • 4 weeks later...
On 29/12/2017 at 10:58 AM, jordanricketts3 said:
Just the length of the bar itself and how far in you did the bends
Sorry for taking so long to get back to you.
Bends are 130mm from the ends and total bar length is 690. Just make sure you slot the holes in the mounting plates otherwise it's a PITA to get on.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
