Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
  • Like 2
Not much of an update but painted N1 vents and parking stick thingo.
Also cut out the middle of the bumper to suit the new plates and gain more airflow as these like to run hot.
  • Like 1
Don't like how big and bulky the airbox is and the stupid sound suppression part that just collects sand!
Started off like this
Chopped it in half and then I was left with this nice flat surface to adhere the new mounting section to.
Also noticed that the round section actually sits outside the chassis rail in the wheel arch, so incorporated a cold air intake port into the new piece.
  • Like 2
Finished re-sleeving the whole harness tonight finally. What a mission but I think the outcome will pay off with a much neater engine bay. All I need to do is buy some larger clear heat shrink so I can branch the connectors off to where they need to go.
I won't tee it all off though until its on the engine as I might be able to re route some it to further neaten it up.
Not Rywire or Chase bays spec but gives it that little extra professionalism.
Got the turbo back from getting rebuilt by MTQ as well. Shaft and cartridge journals were scored, some bent turbine fins and a small crack in the rear housing.
The rod bearings are going to be here until January now, so when I get back from Holidays it's go, go, go!
Edited by Sack87
  • Like 2
  • 3 weeks later...
I got the engine to a stage where I could bolt the gearbox back on and drop it on the subframe. I can easily roll it all out for the remaining work to do on it for ease of access.
Had more delays in timing chains not being in stock locally and having to get them from Japan again and they won't be here until next weekend. Have some small bits coming from over East too which were supposed to be here by Friday but not coming until next Thursday, otherwise I would have bolted the whole lot back in the car.
  • Like 2
Engine harness is all but done. A few little brackets to be made and two more connectors needed. It's 10x neater than what it was.
Injector harness is almost fully tucked.
Degreased the engine bay as I'm 95% ready to bolt the engine up to the body. Someone else has already been in here before me.
  • Like 1
Can you tell us what you had done to the turbo? Looks like a bigger compressor wheel... steel/inconel turbine? Cost? Expected power? So many questions... :)
Looking good by the way!
Edited by andynogo
It's a Billet Intense RS I bought from Scotty a few years ago. You'll find heaps of info on it in the turbo upgrade thread, but good for 500hp he says.
  • Like 1
Very good- should make some decent power!
On 1/28/2019 at 7:53 PM, Akshunhiro said:
Looks like someone had the joy of swapping out the turbo!
Yep. Everything has silicone on it to seal it up, including water hoses onto pipes. I bought a dud...
Got it bolted back this afternoon after doing heaps of little things around the engine that are hard to get to when it's bolted in.
Still heaps of fiddly little shit to go though
  • Like 5
  • 3 weeks later...
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
