Got the airbox mod 3d printed and temporarily screwed it on as it's only minimum infill for trial.
Fits perfectly and the cold air inlet sits just outside the main frame rail.
Also modified the power steering reservoir by making my own bracket as it didn't clear the bonnet when closed in the stock one.
  • Like 2
So I got it going today but have a few issues.
Turbo coolant hose has split, kinda knew it would.
Power steering keeps leaking at the pump so just going to use the old setup
Crank position sensor is throwing a code so it could be f**ked
It keeps overheating. Doesn't matter what I do, i can't get it to not overheat.
Edited by Sack87
1 hour ago, TukeH said:
Whats that strange cliking sound is?
When the water hits the power steering belt it makes that weird noise. You can see the water spitting out of the radiator neck. Took me a few minutes to figure out what it was haha
Edited by Sack87
17 hours ago, Akshunhiro said:
Nice work with the airbox. Would you mind sharing the STL? Or, can I buy one off you? My 3D printer is still waiting to be assembled haha.
Let me test it out first to see how it goes with the heat, then I'll look at selling the STL file if it doesn't melt haha
It only just fit on the Makerbot Replicator bed so yours needs to be the same size.
So I got the coolant bled to a point where I could drive it without overheating and run the engine in for 100km.
Installed a GFB G Force 3 boost controller on a little bracket I made up that fits in the vent. I can monitor AFR later on when I put another sensor in and protect the engine incase it leans out. So many cool features with this unit.
Also had a mate dip the grill in carbon fibre. Came out really good and matches nicely with the ARX kit.
  • Like 4
  • 3 weeks later...
I haven't had much luck with the car as of late. Noticed there was engine oil coming out from the bell housing and whilst under there, I also noticed oil coming from the turbo between the cartridge and turbine housing.
Pulled the box out haphazardly as I didn't have a hoist and pulled the turbo back off too. I cut the rear main seal by accident when installing it on the stand without being able to see the back of the crank. Turbo went back to MTQ for warranty and they reckon nothing was wrong but replaced the oil seals.
Fitted new rear main which is an absolute f**k to get in there and box and turbo back in for test drive.
I put new viscous oil in the fan hub last night and it works/sounds like it's moving a lot of air now. Went to go for a drive, look under the car for leaks after putting it all back in andddddddd oil is pissing out of the turbo feed banjo. FML. I checked every fitting was tight before I put it back in so MTQ have done something there.
So today I started pulling the turbo back off again to fix that.
20 minutes ago, andynogo said:
Yeah... It's one thing after another hey. Keep on trucking- you'll get there! Half price boost night 17 April at whoop ass... Might be a few of us going...
I would but i'll be on arvo shift. I plan too make it down there soon before seasons end.
So it's back in business, no leaks so much success.
Hob drive still says its overheating though but the gauge does not move whether it's 75 or 105.
The new fan oil helped a bit but I think it might be a faulty sensor.
  • 3 weeks later...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
