Took it to work and hot washed the majority of parts. Honed all the bores and deburred number 6 as that had piston melted to the wall. They all came out good but there is slight imperfection on 6 so I will be taking to to my machinist to get it sorted out.
No metal went through the oiling system so all bearings and journals are good to go.
I dodged a bullet here I reckon.
Yup, love that piston! Bore might be alright- fingers crossed.
Nick at Allstar in malaga might be able to tune a Link... worth looking into seeing as a few people have had success with them. Certainly cheaper than haltech. Or go the emanage route?
  • Like 1
Hey mate, awesome post, great job on it all. How did you lean it out if you had the gfb g-force 3 with Wideband integration? Was it not set up or did it just not do what it was meant to do? Cheers man and I admire your commitment to press on, I woulda wiped my ass with it by now ?
I hadn't got around to welding in another bung or buying a sensor.
I was going off what Hobdrive was reading from the factory sensor which according to it, it never went lean. The sample rate must be too slow though.
Overboost function was set up but it didn't work. Maybe it needs a bigger range than .5psi to react quick enough.
Edited by Sack87
Yeah I’m going down the same path (gfb g-force 3 and innovate lc2) as I’ve got an intense billet rs ready to go on. I’ve read overboost function needs to be set 10%higher than target boost, so maybe not enough reaction time hey!! Anyway, good job and I’m excited to see how you get on with it in the future.
New motor is getting, EMU tune, bigger pump, bigger injectors and the wideband setup. Hopefully safer and with more to boot.
  • Like 1
On 25/11/2018 at 7:34 PM, Sack87 said:
Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
Did you go oem rod bearings? What was the reason you didn’t go acl for these also?
You can only get OEM bearings for these. ACL and King Bearings are wrong, full stop.
Do not believe anybody who has a listing as fitting VQ25DET, as they don't.
Cheers for the heads up. Does the same apply for the mains? Oem only? What are you doing about piston and rings number 6? Do you have to replace in a complete set? I’ve read this thread about 20 times haha, so glad I’ve stumbled onto it. Also how good Is Nissan epc/amayama [emoji106]
38 minutes ago, sta934 said:
Cheers for the heads up. Does the same apply for the mains? Oem only? What are you doing about piston and rings number 6? Do you have to replace in a complete set? I’ve read this thread about 20 times haha, so glad I’ve stumbled onto it. Also how good Is Nissan epc/amayama emoji106.png
Yeah same for mains.
You can buy single pistons from Nissan, which I did to replace number 6 and bought another set of rings. All the bores got honed so it's fresh again.
They're both headache savers but Amamaya's processing time is a bit slow. Everything is in Australia for this order yet it takes 3 weeks to get it.
  • Like 1
  • 4 weeks later...
Hey Brendon (spelt your name right this time as I'm on my computer not the stupid autocorrecting phone!), I'm organising parts to do some preventative maintenance on my spare engine and am looking at valve stem seals...
Partsouk has oem for 4.72 (& 4.26 on amayama) each,  and I was also looking at Supertechs. Where did you get your supertechs from and are they the same as rb25det or similar?
Have your parts come in yet? Cheers, Andy
Edited by andynogo
Supertech end up cheaper than stock and they're better.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F272798735032
Amayama and Partsouq have no rod bolts so you have to pay 3x as much to get them from Melbourne. In saying that though, I got them overnight instead of 3 weeks
Thanks for that. Set ordered.
So, I got the motor pretty much buttoned up on the weekend. Got screwed around with rods bolts not being available for two suppliers and ended up paying 3x as much to get them from over east.
EMU was purchased and I just finished sorting out it's harness tonight. Deutsch plugged it so it can be removed easily if needed and labelled all the wires relevant to run. Still need to do the engine harness to match now.
Got a Kinugawa dual port gate coming, innovate LC2 wideband, silicone coolant hoses, new catch can to modify and a fuel pump. Need to buy injectors, new coil packs, plugs, Greddy MAP sensor and looking at possibly getting a stall as well.
  • Like 2
23 minutes ago, andynogo said:
Looking good. Will be very interested to see how the emanage goes- was thinking of that for mine. Who's going to tune it?
Using the tune Matt has online and C-Red to clean it up. No one else will really touch the EMU
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
