R32 gtst hot issues
Hey,
So ive got a 1992 gtst type m that i picked up recently. Its got 100,540km on it now and i just did the timing belt, put on a cheap diy intake and thats it. The car is in spotless condition.
Now im having an issue with the car when it warms up. Originally it would just start hard after the car had been driven. Now the car will start fine cold with no misfires or anything, but as soon as it gets to operating temp it just stalls. If you crank it over the idle will be high, around 1800rpm and then it will start to idle hunt from about 800 to 1800rpm. If you give it any throttle input itll stop at 2500 rpm which im assuming its a limp mode?
I replaced the ignitor and checked all fuses throughout, but im running out of ideas.
Any help would be appreciated!
Dan
20170820_153441.mp4
https://www.sau.com.au/forums/topic/471718-r32-gtst-hot-issues/
Small update.
I unplugged the MAF while it was idle hunting and when i plugged it back in the idle INSTANTLY dropped back to normal and the car stopped running in limp mode.
So now the car is back to starting hard after its warmed up. Itll start up but immediately die. Then it takes 10 to 15 seconds of cranking before it sort of "coughs" to life and then runs perfect again.
Well i still have the factory parts and i may put it back to stock. That being said when i got the car the MAF wasnt tightened down in the inlet tube. Its a super tight fit even getting to the clamp which might be why it wasnt done up properly.
As far as i can tell this car was dealer maintained its whole life.
Ordered a used maf hopefully itll help with my issues. Also going to pull my stocker apart and see how bad it is.
Reading through a few posts scattered across the net, some people said the contact points in the connector have fallen apart due to time and heat among other things.
  • 1 month later...
So the idle hunt and other issues were solved with a remanned afm but im still having hot start issues.
In the morning the car fires up fine but getting in after work the car will fire up and the immediately die. Then the engine will crank for 5 to 10 seconds before it fires up. Today i noticed smoke from the exhaust and it appeared to be black. Ive also smelled fuel when the car needs to crank longer.
Is it possibly leaking injectors maybe?
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
