Anyone Used T&R Coilovers?
Hey bros and broettes.
Has anyone used T&R coilovers before? Seem to be a local distributor re-branding another imported coilover but I'm unsure? They seem reasonably priced at $1200 delivered.
If anyone has used them or has any feedback please do drop here, cheers.
https://www.facebook.com/TandRautostyling/
https://www.sau.com.au/forums/topic/471804-anyone-used-tr-coilovers/
I've never heard of them so can't say if good or bad but for the price, they're not too much cheaper than an entry level MCA blue,  a few hundred bucks. I'd rather get those, as its a recognised company who definitely knows what they're doing when it comes to suspension. A lot of high end cars run mca, their own car (s13 silvia) is last years time attack winner. As they say, the proof is in the pudding. Im pretty sure the dose man can hook you up with pricing too. Also worth remembering the phrase, poor man pays twice.
  • Like 1
Oh mate, if my entire build thread is anything to go by, I've learnt this lesson haha. I was questioning whether to even start this thread, but given I can't see anything but positive reviews even after speaking to an owner of these coils on Facebook, I had to ask :9_innocent:
Just trying to keep you on the right track, lol. They may be ok but do you really want to be a guinea pig. Interested to see if anyone has used these or if they've just hit the market. My advice for MCA still stands.
I think the complete lack of any technical detail would be a give away. 30 way damper adjustment doesn't mean much and in that price bracket there's loads of options that are known quantities. As above, call Josh at MCA they have the runs on the board from all types of motorsport, have been in business for years and provide great customer service. When you flog them out after 5 years I'm sure MCA will rebuild them, old mate from Facepalm will just sell you another set.
Don't do it man :)
You'll hear me go "told you so" again.
If budget is a criterion, I suggest BC BR coil overs. if you can stretch the budget a little MCA X-R would be perfect for road/track use
  • Like 2
Thanks for the feedback guys.
Don't get me wrong, this isn't like a preferred route or anything, and I had all intention of avoiding if I didn't receive anything positive here.
Seems like MCA Blue's would be the way to go for a relatively budget option. I've looked into them and they seem to be the goods.
Aren't they ghecko coils re branded?
Remember, most of those companies will refund money when you post positive reviews on websites, I delete quite a few off SAU alone...
You really need to talk to people who have bought brand new of each brand to get an accurate review. A few years of use will also sway a review.
If money permits and you're planning to track I would skip the MCA Blue and jump straight into the X range.
Problem with the blue range is that Josh and the team refuse to run stiffer springs on then due to the damper limitations so if you intend to track you'll end up with a suspension setup that is way too soft and pitch, roll all over the place.
FWIW I am running 10/7 kg springs in my R33 shit box and that to me on Wakefield is boarder line too soft. Yes some will say correct it with anti-roll bars to stop the roll etc. But what you end up with is a car that's extremely snappy as there is lack of lean and naturally the inner turning wheel will try and move the same way the outer wheel is.
Street car = MCA Blue
Track work = what Dosé said
My direct experience: a mate got Blues for his Evo8. I think he's running 10kg front springs (might be 8kg), can't remember the rear rate. Amazingly compliant on shitty roads (running 40 series RS3 tyres). That's when I knew MCA would be my go-to when I have enough cash.
Thanks for the extra info and advice guys.
I reckon I'll track it 4-5 times a year tops. With that in mind would Blues do or should I ensure I go straight to the X range?
It's my daily, and I travel along Parramatta Rd regularly, so although I want performance I do need a middle ground. Blues sounds good?
Possibly best to call MCA direct and ask the question directly and see what they say.
That's odd, they actually recommend that I go with 14kg front and 8kg rear for my application with the blues.
I've also had them in my car for a year and love them, the car handles like it's on rails and the grip is awesome. I also have Cusco camber arms and hardrace everywhere else which probably also helps.
Regardless, my experience with MCA has been great even when I had a slight issue with them and had to send them back (I had the first batch of blues for R33s) they were very responsive and helpful.
Interesting back several years ago they were not recommending very high spring rates for the Blues so things must have changed.
I was probably one of the very first to get the X-R becauae Josh didn't even have proper boxes made so mine came in cut up old cardboard boxes LOL!
Nevertheless for the money they are excellent even when compared against other coilovers at 1.5x the cost.
Part of me wishes I just went straight to the Reds.
Likewise haha, the boxes mine came in were a Frankenstein of random boxes. when I got my blues, I was asked what I was going to do with the car and they recommended spring rates based off what I was using it for.
They actually recommend 14kg up front and 8kg at the back. I thought it would be slightly too hard, so I decided on 12kg up front and 7kg at the back.
After many spirited driving sessions I regretted not going the 14kg and 8kg so I bought the set they recommended for extra ($100 per pair). Loving them since, bit stiff for the road but perfect for the track and mountains.
Edit:- I wish I wasn't broke at the time and went for the reds also, given how good the blues are for the price I could only imagine how good the reds are...
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
