Anyone Used T&R Coilovers?
Hey bros and broettes.
Has anyone used T&R coilovers before? Seem to be a local distributor re-branding another imported coilover but I'm unsure? They seem reasonably priced at $1200 delivered.
If anyone has used them or has any feedback please do drop here, cheers.
https://www.facebook.com/TandRautostyling/
https://www.sau.com.au/forums/topic/471804-anyone-used-tr-coilovers/
I've never heard of them so can't say if good or bad but for the price, they're not too much cheaper than an entry level MCA blue,  a few hundred bucks. I'd rather get those, as its a recognised company who definitely knows what they're doing when it comes to suspension. A lot of high end cars run mca, their own car (s13 silvia) is last years time attack winner. As they say, the proof is in the pudding. Im pretty sure the dose man can hook you up with pricing too. Also worth remembering the phrase, poor man pays twice.
  • Like 1
Oh mate, if my entire build thread is anything to go by, I've learnt this lesson haha. I was questioning whether to even start this thread, but given I can't see anything but positive reviews even after speaking to an owner of these coils on Facebook, I had to ask :9_innocent:
Just trying to keep you on the right track, lol. They may be ok but do you really want to be a guinea pig. Interested to see if anyone has used these or if they've just hit the market. My advice for MCA still stands.
I think the complete lack of any technical detail would be a give away. 30 way damper adjustment doesn't mean much and in that price bracket there's loads of options that are known quantities. As above, call Josh at MCA they have the runs on the board from all types of motorsport, have been in business for years and provide great customer service. When you flog them out after 5 years I'm sure MCA will rebuild them, old mate from Facepalm will just sell you another set.
Don't do it man :)
You'll hear me go "told you so" again.
If budget is a criterion, I suggest BC BR coil overs. if you can stretch the budget a little MCA X-R would be perfect for road/track use
  • Like 2
Thanks for the feedback guys.
Don't get me wrong, this isn't like a preferred route or anything, and I had all intention of avoiding if I didn't receive anything positive here.
Seems like MCA Blue's would be the way to go for a relatively budget option. I've looked into them and they seem to be the goods.
Aren't they ghecko coils re branded?
Remember, most of those companies will refund money when you post positive reviews on websites, I delete quite a few off SAU alone...
You really need to talk to people who have bought brand new of each brand to get an accurate review. A few years of use will also sway a review.
If money permits and you're planning to track I would skip the MCA Blue and jump straight into the X range.
Problem with the blue range is that Josh and the team refuse to run stiffer springs on then due to the damper limitations so if you intend to track you'll end up with a suspension setup that is way too soft and pitch, roll all over the place.
FWIW I am running 10/7 kg springs in my R33 shit box and that to me on Wakefield is boarder line too soft. Yes some will say correct it with anti-roll bars to stop the roll etc. But what you end up with is a car that's extremely snappy as there is lack of lean and naturally the inner turning wheel will try and move the same way the outer wheel is.
Street car = MCA Blue
Track work = what Dosé said
My direct experience: a mate got Blues for his Evo8. I think he's running 10kg front springs (might be 8kg), can't remember the rear rate. Amazingly compliant on shitty roads (running 40 series RS3 tyres). That's when I knew MCA would be my go-to when I have enough cash.
Thanks for the extra info and advice guys.
I reckon I'll track it 4-5 times a year tops. With that in mind would Blues do or should I ensure I go straight to the X range?
It's my daily, and I travel along Parramatta Rd regularly, so although I want performance I do need a middle ground. Blues sounds good?
Possibly best to call MCA direct and ask the question directly and see what they say.
That's odd, they actually recommend that I go with 14kg front and 8kg rear for my application with the blues.
I've also had them in my car for a year and love them, the car handles like it's on rails and the grip is awesome. I also have Cusco camber arms and hardrace everywhere else which probably also helps.
Regardless, my experience with MCA has been great even when I had a slight issue with them and had to send them back (I had the first batch of blues for R33s) they were very responsive and helpful.
Interesting back several years ago they were not recommending very high spring rates for the Blues so things must have changed.
I was probably one of the very first to get the X-R becauae Josh didn't even have proper boxes made so mine came in cut up old cardboard boxes LOL!
Nevertheless for the money they are excellent even when compared against other coilovers at 1.5x the cost.
Part of me wishes I just went straight to the Reds.
Likewise haha, the boxes mine came in were a Frankenstein of random boxes. when I got my blues, I was asked what I was going to do with the car and they recommended spring rates based off what I was using it for.
They actually recommend 14kg up front and 8kg at the back. I thought it would be slightly too hard, so I decided on 12kg up front and 7kg at the back.
After many spirited driving sessions I regretted not going the 14kg and 8kg so I bought the set they recommended for extra ($100 per pair). Loving them since, bit stiff for the road but perfect for the track and mountains.
Edit:- I wish I wasn't broke at the time and went for the reds also, given how good the blues are for the price I could only imagine how good the reds are...
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
