Target 400 RWKW RB25 DET Torque Plate?
Hi,
I've done some searching and couldn't find a response, sorry if it does exist or if this has been discussed already. I'm building an engine currently for my time attack car. I'm a control freak and want to manage all of the build that i possibly can. However I am not a machine shop so don't have that gear. I've got a machine shop lined up and intend to have my block torque plate machined. Meaning that the rings should also be gaped with a torque plate. So I should provide them with the rings etc and have them gaped. My problem with that is I cannot then check those without the torque plate at home. Now I've just had a light bulb moment... Why not bolt the head on and gap the ring from the underside as I'll have the bare block on a stand. Am I missing something? Is there any reason I cannot do this? Am I an idiot for thinking this is a good idea? Any engine builders or experienced guys want to poke holes in it? I can think of some small negatives but nothing drastic really, just having to reach further in with the feeler gauges, might be harder to square them while deeper in and poor light really. apart from that... I can't see why not? Admin sorry if I'm in the wrong topic, seemed to be the best one.
8 hours ago, GTSBoy said:
You can do it that way.  But given how often your machinist probably needs his RB torque plate, you could probably just borrow it for a week.
That would be idea, but I've never used these guys before, don't know if they'd be down with that. I know if I was them I wouldn't load one out, different story for a long time customer or someone you know personally.
Whats a 400kw torque plate?
I dont build engines or machine things. Are there different kinds of torque plates for different power applications? Just curious thats all.
Edited by Cyko34
34 minutes ago, GTSBoy said:
He's just advising that his target for the engine is 400kW and that is supposed to provide background on how important the idea of using the torque plate when doing the rings is.
Correct, just emphasizing the fact it will need to be right, if I was just slamming together a fresh stockie I wouldn't both with any toque plate at all, let along using one while trying to gap the rings. But for this I am going to a great deal of time and effort to make the engine as efficient, safe and powerful as I can within reason and for my goals.
If  you are going to use them for the machining you could give them a cash deposit.
To just say that a torque plate is required to adequately measure ring gap is not necessarily the best way to approach this issue you are spending an excessive amount of time investigating. There are so many other factors that require consideration. Fuel used? Target rpm? Target boost? Target CR? Combustion chamber and piston crown design? Engine block prep? Parent bore or Ductile iron sleeve? Piston to bore clearances used? The list just goes on and on. If you are so hung up on a torque plate and making sure the deck is square and bore is true, measure it all and make a decision from there. If this is all a bit much for just working out ring gaps, get it to an experienced builder.
Yeah, another good idea, I'll see how I go, but also good to have the backup plan, no-one can poke a hole in the upside down access whit the head bolted on yet, so I know I can do it if needed. Cheers.
Hi,
One thing you are forgetting is that there will ( should ) be a mains girdle in place when the block is bored/honed and this should be in place also when setting the ring gaps with the torque plate on.You will find it pretty difficult with the mains girdle in place to get in there from underneath...
Jason
Jason
No not forgetting the mains being bolted up, yep will be a pain in the arse, but has been considered. If i decide to do it this way I'll let everyone know how much of a pain it is and If i think it's worth it lol.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
