Fair enough, went OK for me with better rotors and pads for 6-7 laps at a time on my boat.
Wasn't setting lap records though.
Bigger is better, but if you're throwing yours out, give them to me for the Silvia ;)
Yea you can make them work however you end up going extreme pad which destroys rotors
also when pushing a heavy gtr 10/10ths they die in the arse really quick
380mm will work well and have ample cooling ( and rotors r cheap as there are many option for gtr, if you want ant to get serious 2mm spacer and step up to 400mm rotor from a later model, however good luck getting them under a 18 rim)
12 minutes ago, ActionDan said:
just be baller and run 19s like I do.
You'd alreayd have 19s if you were about dat stance lyfe.
Nah, you downsize, just like tyre widths.
Throw out those big brakes, replace with tiny slider calipers and 15" wheels
