Time for a serious stance discussion
what kind of exhaust tip do I need
all input appreciated* to make the car hectik
the exhaust is 4 inch straight through with one muffler and a hot dog
ADCE75CC-3DAF-438E-B891-63034B2DD6EA.thumb.jpeg.6b4b4ea36d03f79d1b3ecb0f7109568b.jpeg7EF154E9-2CBE-40AD-B667-17E26459A20D.thumb.jpeg.f82a2f42877d1c2732aedbb2eaaed5fd.jpeg39A522A4-E1A6-4305-8E1F-44F5A22A5C0D.thumb.jpeg.25cec8fe5d5f1c8064221e47f319e1e1.jpeg
* please not like dan above I will listen to all opinions then do the cheapest one eg no tip most likely
  • Like 1
Given this is a track car, just make it flow well and not be too loud. Wanna be able to hear the bearing knock as soon as possible.
Dunno about bigger power GT-Rs, but on my shit box Silvia we lost power down low and didn't start seeing it come back til the upper RPM limit when testing side exit.
Use whatever shit you have to make it as cheap as possible.
Given this is a track car... it should always be in the upper rpm range....
I didn't say it made it all back and then some, I said it only just started seeing it coming back.
It made less peak, less down low and we ran out of revs.
4inch is plenty big enough. Will gain nothing from side exit besides shit sound if you're into that.
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
