Im loving this thread. I have a g35/900 t4 split 1.00 ar going on my rb30/25 with 9:1 and 264 cams. its drive by wire and with vct i think it should spool nicely. I have the 8speed gearbox on the floor ready to go on so full boost changes will be a thing if the tyres can deal with it. it should always be on boost
  • Like 2
9 hours ago, Roy said:
That's convinced me I'll bump up the G30-660 to 770
Any idea if the difference in boost pressure?
Cheers
What do you mean?  In between the two I shared?  They're the same boost
This will be insane.   A mate has a GTSt with a 9:1 RB30/25 with Tomei 256 cams and a Borg S362SX-E that is already a beast from the basement but has a stock 5 speed and will probably get a ZF8 one day.  After the G35 900 RB26 setup I'd be lying if the topic of "Wtf would a divided G35 be like on this thing?" idea hadn't come up - you'd definitely want a wide boost control range setup with it, as even with the less responsive and potent S361 we're having to ramp boost in from very low levels in the early gears.
  • Thanks 1
Cheers
better do the twin scroll properly, here's a good read
https://www.facebook.com/share/p/1XrYzd1jk7/
And screen shots for those that don't like Facebook:
  • 3 months later...
