Many of you know this car well enough already, but here's the full run down. for those that haven't followed the build.
Kilometres - 88-89ks
Power - 380rwkw/509rwhp on E85.
EXTERIOR
  • Z tune style gaurds (Bodyform, properly vented as per OEM, mesh inserts at guard exit)
  • Z tune style bonnet (JSAI)
  • Z tune style bumper (Bodyform, mesh inserts)
  • Mines style carbon mirrors
  • Nismo style skirts
  • Nismo style rear pods
  • 19x9.5 Rays TE37s with 275 rubber, plenty of tread.
  • Black wheel nuts.
  • FRP High spoiler stands.
  • 2pac black spoiler blade.
  • Nismo style B-pillar garnishes.
  • OEM V-spec front diffuser, 2pac gloss black.
  • Nismo smoked front and side indicators.
  • Tinted windows, 1 shade darker than legal.
  • Customised front number plate, trimmed border, rounded edges recessed into front bumper with nutserts and angled for airflow into the cooler. Cleared with Vic Roads and Vic Police.
  • LED parkers to match Xenon light colour.
  • LED replacement for rear number plate light.
INTERIOR
  • Nismo style front mats.
  • Nismo style drop sheet covers.
  • Factory GTR sill protectors.
  • Pioneer media player with remote (bluetooth handsfree etc).
  • Upgraded front and rear speakers (not fantastic in my opinion).
  • Nismo GT500 gearknob.
  • Nur pedals and foot rest.
  • Autowatch alarm.
  • V-spec sensors on MFD (Intake and Exhaust Gas Temp).
  • Nismo lighter (unusued, non smoker car)
  • LED interior dome and map lights.
  • Carbon rear view mirror cover.
  • Front seats/bolters in excellent condition.
  • Steering wheel excellent condition.
  • No hole rear speaker covers (often have holes due to compliance).
ENGINE AND PERFORMANCE MODS-
  • 2 piece Concept front rotors with standard Brembos.
  • DBA rear rotors with standard Brembos.
  • Ferodo Pads.
  • BC ER coilovers (external reservoir with individual damper and rebound adjustment).
  • Subframe collars.
  • Whiteline Rear swaybar.
  • K&N Pod Filters and Adapters.
  • JSAI Pod Filter Shield.
  • AFM Deletes with Aeroflow silicon joiners.
  • KTS Suction kit (modified to remove extra nipple and powder coated) with Aeroflow silicon joiners.
  • Twin turbo pipe mod, powder coated, new badge.
  • Garrett 2859R-9 turbos, newer style with better cages.
  • N1 cast manifolds.
  • Painted exhaust manifold shields.
  • HPI 3" dumps.
  • HPI 3.5" front pipe.
  • Custom 3.5" mandrel bent, v-band exhaust.
  • Magnaflow 3.5" midmuffler.
  • Apexi 3.5" N1 Evolution rear muffler.
  • Custom 3.5" Cat.
  • Adjustable Cam Gears, dialed for response.
  • BC Valve Springs
  • Kelford L182A Cams.
  • Bosch 1000cc E85 compatible Injectors (resister pack delete).
  • Baffled and plumbed catch can with Aeroflow 400 series hoses.
  • Walbro 460lph E85 compatible in tank pump, regulator removed.
  • Aeroflow Fuel Filter.
  • Blitz Alloy Radiator - New silcone hoses.
  • Brake Master Cylinder Stopper.
  • ATS Twin Plate Carbon Clutch.
  • Full length FRP radiator air diversion panel.
  • HKS Oil cooler kit.
  • Splitfire Coilpacks.
  • Plazmaman 76mm Pro Series Intercoole, raw finish, no logo, badge on top of core.
  • Haltech Platinum Pro (Full flex fuel tune, ECU unlocked).
  • Haltech Flex Sensor.
  • Haltech Oil Pressure Kit.
  • Haltech Wideband Kit.
  • Haltech 4bar Map Sensor
  • Haltech I/O Expander.
  • Haltech Mini Can Bus.
  • Nismo style Oil Cap.
  • ARP Headstuds (original headgasket still inplace and no issues).
  • Z Spec Coloured Fastener/Washer Kit.
  • Nismo engine mounts.
  • Nismo trans mount.
SERVICE/MAINTENANCE -
  • All new accessory belts.
  • New Timing belt.
  • New Tensioner/Idler.
  • New Cam Seals.
  • New Crank Seal.
  • New Balancer.
  • New Water Pump.
  • New Cabin air filter.
  • Recently replaced gearbox and transfer case fluid.
  • Fresh Castrol Super Dot 4 Brake Fluid
  • Engine oil barely 1000ks old.
  • Anything that has come off the car has had new gaskets when it went back on where applicable.
  • AC Serviced/Regassed.
ISSUES/BLEMISHES -
  • Few small stone chips in front bar/bonnet.
  • A few small scuffs/scratches along skirts/sills etc.
  • One noticable blemish under clear in passenger rear quarter.
  • One small tear/wear through in carpet right next to foot rest in driver side foot well.
  • One very small burn mark on driver side rear seat, appears to be from solder of rear speakers.
  • Rear antenna removed from car, but available. Radio reception not fantastic but I never use it.
  • Small wear mark on passenger side guard liner.
  • Blemish on cowl beneath windscreen.
  • Passenger side headlight had a plastic repair done on one tab, in white instead of black.
  • Chassis rails have minor indentation from jack stands, actual jacking points are very clean though.
SPARES/LEFTOVERS - (Original = came from this car)
  • Original cams.
  • Original cam gears.
  • Original valve springs.
  • Original shims.
  • Original fuel pump.
  • Original fuel pump regulator.
  • Original rubber intake pipes to turbos.
  • Original Balancer.
  • Original Engine Mounts.
  • Original Trans Mount.
  • Original Oil Cap.
  • Original stick on rear window Antenna.
  • Standard bolt on brake ducts for OEM R34 Front bar.
  • Standard Exhaust manifolds.
  • Standard Exhaust manifold shields.
  • Standard and brand new fuel filter.
  • Standard oil/coolant lines from hot side.
  • Compliance modified rear speaker covers (holes for child restraints).
  • Left over Z-Spec Black and Red coloured fasteners/washers + bolts that were replaced.
  • 2x -9 turbos, 1x mint condition (7000ks still has balance marks etc), 1x with damaged compressor wheel, but spins freely.
  • Genuine airbox, side port, snorkel with new foam.
  • Apexi Panel filter to suit airbox, done a few hundred k's max.
  • Greddy radiator diversion panel, painted black.
  • Generic oil filter relocation block plate with lines to add on to the HKS cooler kit, was gong to fit next service.
  • Random stickers from parts purchases if that's your thing.
  • There may be some other bits I've forgotten.
I would consider a few things as part payment, though I realise the likelihood of people having them is low.
  • CA18DET engine: Forged, stocked, spun bearing etc - priced accordingly.
  • Close ratio dog box with CA/SR bell housing.
  • A half decent dual axle car trailer, tilting/bagged, but low car friendly.
A few extra bits of info to assist.
  • Car comes with 2 keys, 1x Original GTR key, one genuine but generic Nissan key I had cut. Alarm only has 1 fob, but another can be still be purchased.
  • Not interested in any form of Crypto as payment.
  • No, I will not meet you half way to inspect it, I've tried to provide as much info as possible to assist on this front and can take more photos as needed.
  • Inspections welcome, but you will not be driving the car until it's clear that you're serious about buying.
  • Mechanical inspections welcome, if the mechanic is not known to me the car will be put in valet mode if driving it is necessary.
  • Contact details of tuner who did most of the bigger ticket mechanical jobs and tuned it are available.
  • I have a bit of doco to go with the car, receipts, pictures of the build, import/degreg papers etc.
  • No rush to sell so please do not waste either of our time with low ball offers.
  • Overall the car is in very good condition for a 17yr old vehicle and has been well looked after. It's lucky to have done 2000ks in 2 years, I simply do not have the time to enjoy it.
Located Australia - Albury/Wodonga, happy to assist with transport as required.
Album: https://photos.app.goo.gl/E7MZpPg9oQs5kZxn2
Price 100k ono
Edited by ActionDan
  • Like 1
  • Confused 1
https://www.sau.com.au/forums/topic/473108-r34-gt-r-z-tune-inspired-build/
Getting a lot of requests for videos, I assume given my distance from capital cities.
I've added 5 videos to the album and can take more as required.
I'll have the car out tonight for some professional photos, then not again for a while so any requests should be made quickly :)
Car is now on carsales as I begin to make a more conscious effort to sell it to pursue some other things.
Offers welcome.
Some new photos taken recently so I have something to frame and look at on those cold winter nights...
  • Like 6
Very appealing 34gtr.
Unfortunately I've spent not far off this on my build that comes knowhere near this.
You should sell it relatively easy given some of the other crazy asking prices I've seen.
Congrats on what you've created.
Thanks Paul,
It's not a cheap hobby and I hope the car represents good value, but the market will determine that.
I'm not expecting a quick sale, despite being happy to discuss offers.
See how we go :)
  • 4 weeks later...
  • 3 months later...
  • 1 month later...
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
