Received my kit yesterday, and fitted it up this morning, took a couple of hours to do from start to finish including removing old standard unit.
Everything bolted up perfectly and lines up spot on, great quality and an excellent upgrade for the electrical system ready for any added extras down the road.
Personally I found the best course of action for fitment is to drop the old unit off through the gap between the radiator shroud and the power steering lines etc, and have the extension bracket mounted to unit not fully tightened, that way you can wriggle stuff around when lifting the new one up through the gap, hardest bit, and part that illicits the most cursing of engineering design etc. Is the placement of the lower pivot bolt, you can either see it, or you can get a hand in there to fit it, Never both! Once bottom bolt is in the rest is easy as.
Electrical system is now a lot more stable and also a bit quieter on the belt noise level with the new pulley too, so I will be recommending this kit to all of the local jdm nut bags and passing them the info/links etc.
  • Like 2
Yep, 100% agree, ive only recently got my car back from the workshop so haven’t done a heap of driving but I’ve already noticed the electrical system is better, before with lights on and stereo on I would see a drop in voltage and that was only running one fuel pump. I’m now running three pumps, no issues, no volt drop.
Very happy customer here.
But I didn’t fit it, I had the workshop fit it.
  • Like 1
3 fuel pumps? jeebus I'd hate to have your bloody fuel bill hahahaha, 2 questions... why 3 pumps? and secondly are any of them a "drop-in" upgrade that aren't as loud as a rotary13B sitting in your boot?
I might look at doing a pump and reg upgrade in the future but don't want a massively loud thing resonating in the wagon, so I'm looking for recommendations of an in-tank minimal fuss type of thing, any suggestions?
Fuel system was done by DVS Tuning, radium surge tank with twin walbro 460’s staged and another walbro in the main tank feeding the surge tank.
It’s unbelievably quiet, I’m very happy with it. Supports my 500kw and is good for substantially more should I wish to pursue more power in the future.
This is why I upgraded the alternator
  • Like 1
22 hours ago, cul8er said:
Anyone have to do a power cable to support the extra 70a due to bigger alternator ?
mine already had much thicker cable than standard due to the car having a uber-ridiculous stereo system in it when i got it, but can buy 200amp rated cable  10mm thick in super cheap which is about $8-10 a metre that'll be more than up to the task, then go to an electrical wholesaler or battery shop for the crimp on ends
Just fitted a rat32r kit with an alternator he supplied. Very nice kit and straight forward instalation. Idle voltage has gone from 14.2v to 14.45v. The Attessa light is staying off now, so the only remaining issue is the ABS.
  • Like 2
  • 1 month later...
Do you know how i can get hold of rat32r i have messaged him on here with no response
Would it be possible to see a pic of an RB spec Mitsubishi Alternator next to the LS Mitsy one please .
I'm very interested in this kit but just curious to see if the LS one is larger in diameter compared to the Nissan supplied one .
Mine would be for an R33 spec RB25DET .
Thanks in advance , cheers Adrian .
    • Get something that can spray a bit, something like I'd use is a pressure pack for weed sprayer. I use one with degreaser. Spray it on (make sure you're fully covered up, you don't want that shit on you, especially face/eyes). Alternatively, a paint brush will help here as you can brush and work at the stuff quite aggressively.   Be aware, citric acid can eat metal away and will cause it to rust more later. So make sure you neutralise it when done, and give the fresh metal some protection. That hanger, I'd honestly bin and get something like the Frenchy's drop in replacement. The tank, again, I'd look for something else to replace it with. Remember, as metal turns to rust, it means there's less metal there now. So some patches of your fuel tank are likely to be quite thin.   Personally, Id focus on the front end of things, IE, how did the injectors get clogged if they're meant to be after a fuel filter. Then, once the front is sorted, I'd rig something up, even like a small surge tank, and make sure the engine is now running and all behaving. Then I'd replace the fuel tank and fuel hanger and pump. Also, I'd already be preparing to ditch your fuel filter...
    • That's looking great! Are you planning to do things like all hidden wiring with it, or you're planning to have it look more like we'd expect an RB in an engine bay to look like?
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
