Hi Folks
Has anyone ever seen anything like this before with boost spiking?
Below is 4 small traces from 4 pulls.
Run 1 was done with a vacuum line running from the compressor housing to the wastegate.
Run 2, 3, and 4 were done running the line through the (Borg Warner) 3 port boost solenoid with it ENTIRELY UNPLUGGED ELECTRICALLY.
I can only surmise that the boost solenoid itself acts as a restriction. In run 4 I stayed on the gas longer and you can see it does drop to wastegate pressure.
Note: I've had issues similar to this with:
a) 4 port boost solenoid (MAC, very old, replaced)
b) 3 port boost solenoid (MAC, literally fell apart and returned)
c) Borg Warner EFR boost solenoid
If something else can cause this, what could it be? The gate was/is a 50MM Progate single.
I am assuming the wastegate is fine, as a hose directly from pressure source to wastegate works as expected. I have had (briefly) a MBC which also works as expected sitting in the line in the past. I have replaced all hoses and shortened them to no effect.
Is there anything else to check? I'd love to run between 10 and 20psi, but it really looks that if I hook up any boost solenoid I'm going to be dealing with at least a 20psi spike before settling down to whatever boost I specify (that part does in fact work).
https://www.sau.com.au/forums/topic/473282-stupid-boost-spike/
Too much power. Stock cars may run it but Skylines sure don't like living that long up there. 12psi is more than enough, 10 is okay but I'd love a little more than that, but really what I want is electronic control to actually hold the line flat instead of it falling off which is what you'd expect from a MBC or just a line to the gate directly. (12psi is 330rwkw)
Can't see how removing the plumb back would affect this? The plumb back is a 2inch piece of exhaust that is well over a meter long before it joins with the exhaust again, which would be unused when the gate is shut, I can't see how adding a solenoid in the line would affect it.
1000000000000000000000000000000000000%
It's pretty easy to see, blow air in one side, see where it comes out. Attach hoses inline with that flow, considering it's unplugged and all... did check to see if its leaking using the same scientific test and doesn't appear to be.
80465d1372138438-borg-warner-efr-boost-c
Here is a (blurry) picture of it plumbed in. The electrical connector was disconnected further up the chain. When I join the two hoses I've labelled together with a straight barbed connector, I get no more spikes.
The BW provided hose to the compressor looked a little kinked, so I replaced it with exactly zero effect.... on either configuration (plumbed into solenoid or past it straight into the gate).
My set up: drilled and tapped nipple in compressor housing going to mac valve controlled by Link through to Synapse 50mm wastegate. Result pretty flat boost curve (attached). Can you swap out your wastegate to test it?
Yep, this is running a (genuine) 50mm external gate.
I can get the thing to hold boost fine for 20psi, similar to KiwiRS4T posted just above, the problem is I may not want to run 20psi, I may want to run 15psi or 12psi in the fashion that was posted above, or 17 psi etc. Or say pull 5psi boost per gear in 1st, none of which really has much effect if I'm spiking to 20psi semi-controllably.
I just found it astounding that the spike happens when the device is plumbed in, even with the solenoid is unplugged. The logic that air has to do a 90deg vs not is the only real difference here but I just can't see that causing this oddity!
On 2/7/2018 at 11:45 AM, Kinkstaah said:
Hi Folks
It sounds like you have a leaking WG diaphragm or hose to the top of the gate. Suck on hose to the top of the gate and suck on it and ensure it holds vacum.
Jason
Update:
Plumbing the lines like this fixed it.
Seems that it really didn't like being in the simplest possible method.
Bit of playing with PID and start duty afterwards, now right as rain.
  • Like 2
Strange, I would have thought that plumbing one line directly to the bottom of the gate should be the most spike resistant/basic way to set up the gate especially if looking for low boost, like how most IWG's run.
It still makes no sense to me how this can happen by adding the solenoid in the middle of the vacuum hoses, when connecting the hose directly does not have this spike, with the solenoid unplugged, doing literally nothing.
Is it an example of the Dunning Kruger effect when you:
1) Try something, then get stuck
2) Ask for help
3) Take that help on board, get the problem sorted
4) Post up results so other people can find it?
  • Like 1
It still makes no sense to me how this can happen by adding the solenoid in the middle of the vaccum hoses, when connecting the hose directly does not have this spike, with the solenoid unplugged, doing literally nothing.
I'm assuming that setting it up in the pictures I posted above means that that line to bottom of the gate is always 'pressurized' and not going through anything (i.e the solenoid) and no more spiking.
2) Ask for help
The way you now have it plumbed is the normal way of plumbing a three port for most applications.
Edited by infomotive
Quoted wrong
A lot depends on the design of the wastegate.  The Synapse wastegate  has four ports - two above and two below the diaphragm and different combinations can get close to the desired boost levels leaving the Mac valve and ecu with just a trimming job. i saw a wastegate a while back with no springs and a solid piston instead of a diaphragm so it was all done with the balance of the air supplies (with a mac valve and ecu).
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
