First serious mod done to the wagon: RWD "conversion". The reason: the wheels I got for her apparently had a slightly different rolling diameter (3mm) and neither ATTESSA nor my transmission were too happy about that. Yes, i could have gone through the trouble (and money) to find matching tyres (current tyres: Falken Azenis FK453 in near imaculate condition) but I don't think the mrs would have liked that too much. Dropping the shaft was pretty straight-forward, although I did resort to a dremel for some stubborn bolts :)
Yes, that's in front of my house
No, I don't have a garage
Yes, it was -2 degrees Celcius
  • Like 1
https://www.sau.com.au/forums/topic/473414-staceys-project-page/
So, last night as i was driving home from work my 4wd lamp started flashing. I figured this is logical considering i dropped the front shaft in the weekend. Just a  bit strange that it's started flashing now and not right away. My theory is that the attessa pump or ecu is going haywire. Any thougts on this? What would completely removing the attessa system do?
  • 3 weeks later...
Short clip of the wagon destroying a pair at the burnout contest last week. As you can see, lots of white smoke from the exhaust which tells me she's running really rich (because nissan....). I ordered a consult-bluetooth thing so I'll be testing that after the weekend. Next step would be an afr gauge/wideband sensor and some sort of AFC, although from what I've been reading lately it can get tricky considering she's an S1 auto...
VID-20180314-WA0002.mp4
  • Like 1
3 hours ago, Ben C34 said:
That's a decent effort.
What kind of wierd platform is that? Heaps different to Aussie burnout comps!
Yeah well considering she's completely stock and quiet as heck, yeah it was a pretty decent effort. It's my first time doing a burnout like that. Apparently that's how they do it here with the platform, might have something to do with safety or the fact that they (the racetrack owners) don't want their tarmac all ruined and stuff
Commentator is speaking Dutch so Netherlands or Belgium?
To OP; try disconnecting the switch to Attessa pump (see below) or you could just tape over the light! Have you pulled the 2 4wd fuses (one in the cabin fuse block behind the coin tray and one under the bonnet)?:
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
In my S1 Stagea its a very small black plug taped to a loom with a single yellow wire with a green trace going to the plug and a single black wire going to the socket.
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
You need to do this every time you start the car.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
And if you plan to do this a lot you can put a switch in somewhere.
Disconnect it.
I'm living in the Netherlands, yes :)
I've not pulled the fuses (yet) so that's the first thing i'll try. The car is basically always in 2wd mode since the front shaft has been removed, just the ecu doesn't know that i guess..
If the fuse thing doesn't work i'll do the bleed thing :)
  • 3 weeks later...
So, coming sunday i'll be going to a fellow wagoneer who's parting out his stagea. Gonna check out which parts i'll be taking, already made a list:
Tein Coilovers
Front Mount Intercooler
3" Turboback exhaust
Apexi Powerfilter
(R33) Gtr Brakes
Question is now, what differences i'll feel (aside from a slightly stiffer ride and a louder exhaust) with these mods? Will there be a significant increase in performance? Will defintely get it tuned after the mods.
  • 1 month later...
So, the time has come! I'll be picking up the above mentioned parts in the coming weeks :D
At the same time, i've been thinking out loud about doing a manual swap (surprise surprise). I've seen the writeup here and it's definitely insightful. However, i would like to stay the RWD route so instead of using a gtr box i'm considering a gtst box. Also, i'm pondering about what to do with the sump. I wanna believe that a rwd sump would fit, given i'd have to modify the oil pick up and drill/tap some holes.
Anything else i need to keep in mind when going this route (aside from everything mentioned in the writeup of course)?
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
