Hey guys,
I d like to ask for advice... My newly bought skyline running perfectly on 7 psi but if i raise the boost to 10 psi it cuts out at 6000 rpm and i just cannot tune it out.... when the engine is hot its getting worse (5500rpm)... I connected a  smoke machine to check for leaks...I marked the blocked pipes with red X....the smoke is immediately (at low pressure) coming out from the crankcase and from the inlet manifold...
It just doesn`t make sense to me how can it smokes from the engine when everything is blocked... Is my turbo leaking through the bearing housing back to exhaust and through the open valves comes out at the inlet? Or is it normal? Any idea? I m kind of getting hopeless for now maybe just i m the dumb and cannot tune it out (datalogit power fc, Z32 maf)... pls don`t spare me everything helps, have a good one
https://www.sau.com.au/forums/topic/473789-rb25det-turbo-leak/
Sorry about that i just didnt make a picture how the smoke was connected so i tried to improvise.... I connected the smoke to the inlet before the turbo (blue arrows).... I blocked the inlet from the intercooler so it should hold the pressure... but it s not holding any pressure since the smoke is coming out from the inlet manifold and the crankcase where the red arrows are with the ???.... And that s what i m asking if it s normal?
I assume you have the breather pipe and bov plumb back pipe blocked that comes out of your stock intake pipe. Try blocking it closer to the turbo, for example, block it before it enters the intercooler.
or, enter smoke right after the turbo and block off the same as your picture^^
NEO25T: I think I m gonna try it on the weekend
Kinkstaah: yeah it is an Apexi Power FC with Datalogit I have a log file what is happening...
the AFR at the cut point is about 10.75 (so it s not too rich or too lean) I ve tried to adjust the airflow data....change the whole MAF...still the same... after the car is hot the cut is happening at 4320 mV or less... It is a Garrett GT28 turbo, 7psi wastegate with a turbosmart tee set to 10psi
RB25detonator: yeah i ve done it too leaking out on the same places (crankcase and inlet)
Out of curiosity how did you block the pipes?
The easiest way i found was to bag the end of the pipe with black plastic and clamp it back together.
What spark plugs are in it, thinking back mine cut out like a rev limit at 6k when i got it. The plugs in it were nasty and new ones fixed it up
On 4/18/2018 at 8:50 PM, Ibanex said:
yeah I used rubber gloves with clamp for alloy inlet and for the hose used degreaser can and clamped it  for smaller pipes just bolt and clamp.
I thought about the plugs too and I changed them last week for NGK BCPR7ES... they should be fine right?
They should be OK but Iridiums better. If you still have stock coils are your plugs gapped down to ).8mm?
the only thing is that it really doesnt feel like a missfire...it just cuts out all together...  these plugs came already gapped to 0.8mm and the coilpacks (blue splitfires) should not be older than 2 years... so not too much left just keep on experimenting and spending some money...
If that is a full WOT pull, from the entirety of the video (i.e not backing off) and boost is dropping into massive vaccum like that, I'd be putting my money on that stock silicon hose sucking shut.
Especially given you said it runs fine on stock boost...
  • Like 1
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
