Im looking to put all new rubbers in the front end of the 32 as it is getting a new engine so thought i would while its all out.
ive looked around and have two options that ive found, nolathane or superpro
Whos has used each?
Recommendations?
Price etc?
https://www.sau.com.au/forums/topic/473971-nolathane-or-superpro/
Well, yeah.  Superpro is pretty much the default choice.
Look up my recentish posts on the topic of the GKTech FUCAs.  Worth a look at, even if they aren't road legal.  Urethane bushes in the stock Nissan 32 FUCAs arre not great.  Same same with using rose joints on the caster rods, rather than urethane bushes in the stockers.  I posted years and years ago about how much better they were.  If you were to do those things, then the only remaining bushes in the front end are the lower control arms and the ARBs.
I've been running just about every superpro bush since 2012. Control arms, castor, steering rack etc. While they're fine and have been silent, if you can simply put in a new adjustable item with new bushes, do that. Don't bother replacing the bushes.
2 hours ago, Adz2332 said:
whiteline do just the replacement bushes also?
i'm pretty certain whiteline and nolathane are same company (Redranger Pty Ltd). I have some whiteline, some nolathane, some superpro across the car...can't say I see a difference, just the different design you may prefer between manufacturers, eg, diff bushes. Urethane bushes have been around that long I'd be surprised if either company had some miracle advantageous compound over that of their competitor...but still charge a similar price for their product. I'd use whichever you can get cheapest.
Although as above, might be better to just spend a little more and get whole new adjustable arms, and some bushes are better rosejointed.
hmmmm....I saw a pair of gtech upper arms snapped at the welds just last week. the car looked hard to drive after that. I suspect there is no good option for 32 upper arms, maybe the nismo brackets are the best idea.
I did run nolathene bushes back in the day, pretty sure they went broke and got bought our like Andy said. They worked fine but degraded quickly over time, they only lasted 1-2 seasons before needing re-doing which was a PITA to do again.
Hmm. I flogged out the trailing upper front bush in one track day. It was a white line. Thing that fixes it is moving the pick up point for that link.
Do the super pro bushes have pigtails for grease retention. The photos don't appear to show them. Or are they all the same? The nolathane bushes are dimensionally the same as the Whiteline bushes.
That's not really what I wanted to hear about the GK-Tech uppers.  I'm going to have to cross my fingers and hope, because I'm not going back to stock arms.
The recommendation for stock arms is all well and good, but if you need to correct camber you're up shit creek with the stockers.  That's the reason that I put (originally) Whiteline and then at least 2 sets of Superpro in the front of my car over the years.  Even with grease nipples added (I added them myself in ~2002) the bushes take a beating.
I might have to modify my spare brackets to Nismo spec and try with new urethanes in my adjustable stockers if I break a GK-Tech arm.
well the good news is my upper arm bushes have been lasting twice as long (you know 3-4 weekends instead of 1-2) since I move the LCA mouting points outwards 20mm. Its definitely a 30 year old geometry issue.
9 hours ago, Meathead said:
If your OEM ones are flogged out just replace them with OEM or Nismo.
Wouldn't waste my time with short duration cheap plastic stuff unless you like pulling it down a lot.
Who sells OEM?
    • Only if you do not You will not be able to drive it with any serious load without risk of it pinging, which will either slowly or rapidly kill it, depending on how bad it is.
    • Hi guys, I’m new to the GTR scene. Picked up an R33 GTR earlier this year that needs a lot of love. I’ve been going through the hot side, changing all the gaskets and while it was all off I managed to score a set of -9s. It still had the stock ceramics so I was pretty happy to get the 2860s.  I live in a small country in the pacific with 0 performance car scene. No dyno’s no performance parts, let alone stock parts for a skyline. I order everything from Australia and do it myself. This means I’ll be running the stock ECU. Maybe down the track I’ll get an aftermarket set up and do a remote tune.  Will the car run -9s on stock tune safely?  I have a very heavy foot so I really hope so 😂   thanks guys
    • perfect, no rush to address the leaking bush then, it's not doing much/anything
    • I'm not sure if it will bolt up, but.... I'm reasonably sure that the ID of the runners is somewhat smaller on the NAs. So it probably wouldn't be a good match at the flange where the top and bottom meet. So that would be a reason to not do it. And the skinny runners would be the bit you're keeping, which would be a reason to no do it. You'd want the big runners if you were doing any work to swap stuff. Why not just use what you've got, like nearly everyone else who has +T'd an NA? You don't need or want the TCS throttle or other stuff that is specifically DET inlet/crossover.
    • lol already been put in temporarily 3 years ago
