Mid-Week Update:
Attack the issue with the oil cooler lines and fittings. It now has the correct size AN fittings and all new black hoses. New mounting brackets on the oil cooler also adde d. The oil cooler will be mounted behind the intercooler and parallel with the car. Pics to come soon!
To add a little more to the upgrades I asked to have the "Twin Turbo" Divider Mod to be done.
Edited by Dewayne2121
  • Like 1
ECU and Flex Fuel Sensor came in. The ECU itself is very small and compact. Picked up the Plug and Play harness for the RB26. Got a bluetooth sensor also to run the Real Dash (or apps similar) on a tablet.
  • Like 1
  • 3 weeks later...
A lot of progress has been made on the build and here's an update:
The motor is back in the car and running flawlessly. No more oil leaks and compression checks across the board are amazing!
37679531_10214208858708029_5192286981765201920_n.thumb.jpg.e7a7bbcf3fddc1c124f37ef7a4802f6e.jpg
Wrinkle Black Paint really makes this look great!
37793926_10214208862588126_3375576413250781184_n.thumb.jpg.e58a46ec3a3deb41daaff590107c101d.jpg
Radium rail installed w/ stock injectors. Will place the new injectors in once we get the ECU Plug n' Play Harness.
37669685_10214208860468073_1630960723385384960_n.thumb.jpg.228c7178a53a3f3e76e25082c80e07a1.jpg
I love just admiring the new look on the intake side of the bay. Aeromotive FPR w/ pressure gauge. The  FlexFuel Sensor is also mounted on the strut tower. The Aeromotive fuel filter is the only thing not in the bay. It is under the car with the fuel lines.
37744613_10214208902389121_9139847279568486400_n.thumb.jpg.e2ce3f3200a47e2766fe4e317032c4d6.jpg
37661140_10214208862188116_8900761345146748928_n.thumb.jpg.6aaa4138ad2ea7b23a6861e8a08c142b.jpg
Oil cooler mounted w/ new lines
37734994_10214208897669003_2517890947686072320_n.thumb.jpg.a07bfebcef1aed08631151f552b72d27.jpg
37793926_10214208862588126_3375576413250781184_n.thumb.jpg.96b244b7841d32ff8eb94475c2551678.jpg
37686314_10214208902069113_6366844293931335680_n.thumb.jpg.3a6676c32b21c6e8cecff834d3910dda.jpg
This is the current ride height on the MeisterR ZetaCRD. Havent got a chance to drive so no review on the stiffness/comfort just yet.
37778094_10214208862868133_1216537172920762368_n.thumb.jpg.0d3fb2f1037bd04ca9d9ba51541d0822.jpg
37780316_10214208895228942_8638342756076355584_n.thumb.jpg.74f64c225a18ee0325ffc46a624d035a.jpg
Definitely gonna have to roll the rears with this setup.
37675584_10214208895428947_3866414235139440640_n.thumb.jpg.7e7e52becbeb78d39370b04b2d3fa39a.jpg
  • Like 2
Things Left:
Swap over 1000cc injectors and PnP clips
Delete MAFS (Turbo intake pipes 3" w/ compact filters wrinkle black)
Custom oil catch can behind battery made by Go-Autoworks. (http://go-autoworks.com/)
Order GM IAT sensor + use M12x1.5 to 3/8 male/female adapter
Install ECUMasters ecu, wire subharness (Wire in Wideband)
Tune Session Pump to E85. Gonna pull the 4WD fuse and see what it's capable of. Will update with more photos as they come in.
Nice build. Should be a nice little combo when done
there's a IAT sensor that bolts into the stock position and sticks out farther, with the faster response/open tip that i belive NZefi and Kudos motorsport has started selling, would recommend that for ease of install/neatness.
Im currently using NZefi's GTR Injector Resistor Delete at the moment so I will check this out and see. Thanks for the info!
  • 4 weeks later...
Quick update and just a visual of the build thus far...
So all the parts for the build have been ordered and on hand at the moment. My battery was constantly weak and we came to realize once there's a ton of random harnesses that are not being used. So to clean it all up Zack is going in there and getting rid of the unnecessary wires. Getting the seats done in perforated leather where the darker blue is on the seat and perforated Suede in the middle. Have suede e-brake and shift boot and will be covering the back seat with black carpet to match! Hope you're enjoying it so far!
Deleted the Stock Blow off Valves since going MAP.
Thoroughly enjoying the videos of the progress. Keeps the parts added and work done as receipts. Hope y'all enjoying them as well
  • 1 month later...
  • 2 months later...
Quick Update:
Custom Catch can installed to the right of the radiator.
1000cc injectors dropped in and idle set up.
Bought an AEM IAT sensor and moved it to the intake piping next to BOV.
Installed the seats back into the car (Need to install the Shift/E-Brake Suede Boots)
Car should be with the tuner before the month is out. Gonna do the pump gas then e85. Dyno and road tune for drive-ability.
Jun Style front lip installed and fenders pulled and rolled.
Also, got the old Optima Yellow Top battery out of their for a more suitable choice.931631418_12Jan2019.jpg.95caf0dd2ff57501b3d435d72f7baf69.jpg
  • Like 2
Pulled the car out of the shop for the first time in Months!!1943842887_OutsideMLK.thumb.png.218e58d5bd06f7ab5be695d9a1feb406.png
This is where we're at so far.
Quickly got the bumper and hood mounted back on Friday (January 18th) as the tuner called and was available to start on the pump gas tune. He picked it up that afternoon and worked on the tune and boost controller on the pump gas settings. Only 2 things came up.
  1. The power steering belt shredded for whatever reason (thinking just age). It has been replaced and all is well.
  2.  Lower charge pipe blew off at high boost/rpm... it may have not been tightened all the way after adding the bung, then swapping to wiring the bung. It's been reinstalled and all is well.
I was then informed Sunday (January 20th) that the tuner will be going out of town until the 4th. At that point I told him to bring me the car back so I can get the alarm taken care of instead of it just sitting idle. Got another Viper 5706v Two-Way Alarm to get put in since it was removed with all the harnesses that were tapped in the wires.
So, all that should be left is the gas swap and E85 dyno time.
I was sent a breakdown of the tuning bill so far.
This is what the tuner was able to accomplish thus fur:
3 hours tuning AFR and boost controller
2 hours of ECU tuning AFR and accel tables.
Now, I have to wait until he is back AND have the time to get it on the dyno and tuned... Almost at the finish line!
  • Like 2
  • 4 weeks later...
Sneak peak of the Dyno Tune session. This was dialing in the pump tune with a few pulls. Im in love with the BOV sound ! Sounds like the 2530s are trying to suck all the air in the room
Hey man, I've been following this since you first posted last June. I'm enjoying the way it's coming together for you and really looking forward to your opinions of both the ECU and the MeisterRs.
P.S. I'm just up the road.
Edited by Silverhks
The ECUMaster EMU Black has been a great product, but the customer service was not the best initially. I was on "backorder" which turned out to be a lazy employee who was procrastinating on making the RB26 plug N play harnesses. Once the harness was made, I was sent a SR20 pin out instead of RB26. Once that debacle was handled, there wasn't any issues as far as the product itself. They terminated the guy who had me on backorder for 2 months, but the motor was out of the car at that moment so i wasn't too upset. The tuner has no issues with tuning it and once we had the right pin out the systems on the car work flawlessly. I have to get back to you on the MeisterRs after I get it back and get a few weeks of behind the wheel time.
  • Like 1
    • sold listed as a Tomei LSD 1.5 Way For 1998+ Nissan Skyline ER34 25GT RB25DE w/Open R200 https://www.ebay.com/itm/174006114594?campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=&mkrid=711-53200-19255-0&loc_physical_ms=108689&loc_interest_ms=&campid=5338967980&mkevt=1&mkcid=1&toolid=10050&customid=71883f2ccc571356e0a757bc7adfdde2&mkrid=710-53481-19255-0&loc_physical_ms=108689&loc_interest_ms= it went in like butter all gears, alignment, back lash etc, rotation and clearances correct, and if rolling all rotates smooth and free when coasting down road , clutch in or out over 10 mph smooth... its the binding, clunking and jerking from a stop that is most concerning, also seems like its going to tear the tires off in 10 miles of normal road driving.
    • What 1.5 way? There's no such thing really as a 1.5 way, just different ways of explaining 2 ways with different ramp rates. HOWEVER. In any driving in a straight line your 1.5 or 2 or 1.7 way should have no clunking at all. With the clutch fully depressed the diff should be silent (unless it's welded but I'm assuming it's not). Something aint right here.
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
