First pic its the oem boost solenoid. Do you have some sort of boost controller installed?
Second one looks to be somekind of diy switch. Could be for anything really. Possibly a power switch for aftermarket gauges, lights or something like that. Only way to find out is to follow the wires
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891059
First picture is a boost solenoid which may have been connected some type of boost controller before it was unplugged.
Second photo is a on/off for something as others have said - if you want to find out take it out and then follow the wiring. My guess is it was for something boost related but has since been removed. Very stealthy to have it mounted by the door.
Third photo is a fire extinguisher holder. Most Skylines (all, if I’m not mistaken) came with portal fire extinguishers but most have been removed.
Cheers.
  • Confused 1
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891068
11 minutes ago, adey88 said:
2 hours ago, FedBpy2018 said:
Is this thing normal?
I believe that's for a flare (not fire extinguisher) as required by law in Japan.
Actually, now come to think of it...I think you correct. Then some people place fire extinguishers there but originally yes it was a small black flare.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891074
People don’t put fire extinguishers there because it will be hard to reach while in the drivers seat, usually it’s on the right hand side of the passenger foot well or under the drivers/passengers seat. Also the flares are red.
  • Like 2
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891079
Right, you are (photo of flare on same spot).
images?q=tbn:ANd9GcSvXAHjllvKPsvxpO5YHvo
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891081
Since you are not using the stock boost controller you must have an alternative. The simplest would be an R32 actuator. Trace back from your actuator to see where the line goes and you will find an aftermarket controller if fitted.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891090
I followed the wires from the actuator they lead inside the dash through the firewall and cant follow from there, this sunday im going to take the dash apart and find it, has anyone got a guide to do it? If it was a car i normally work on i could take it apart in less then 5 mins lol, im guess for this it will take a few hours to pull apart and put back
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891151
That's a factory boost solenoid with factory wires that will lead back to the factory ecu. Hardly worth chasing, certainly don't pull your dash apart to solve this non mystery.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891153
3 minutes ago, FedBpy2018 said:
So dont bother using it then?
Well, that depends on what other boost control you have.
Also, there is an obvious misunderstanding as to what terms is being used here.  The item in the photo is the boost control solenoid, as others have said.  The "actuator" referred to by Kiwi is not that solenoid.  He meant the actuator that is mounted on the turbo that pneumatically pushes on the wastegate lever.  Not the same thing at all....although, obviously, related.  All part of the boost control.  Anyway, there are no wires on the actuator.  There wires on the solenoid are as Ben said.  You should follow all advice given.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891157
From what i can see inside the car there is no other boost controller, also what causes a door window to tilt towords the inside of the car? Photos attached, the purple line on the window is the window hitting something on its way up so i dont use it but previous owner did, the first photo is what a owner had done to bypass the solenoid
Edited by FedBpy2018
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891163
Unless that's an RB20 actuator (and I can't be stuffed searching the part number to check).....then you have a whole 5 psi and your car should be as slow as all f**k.
The window is easy.  The stuff inside the door that keeps the window aligned (so, either the runner channels/rollers or the felt pads near the top) are stuffed.
https://www.sau.com.au/forums/topic/475399-what-is-this/#findComment-7891165
