The Old ATR43SS2 (Circa 2016) was a bit more urgent to drive, however it's a bit harder to compare as the motor had stock cams and power would nose over about the 6500rpm mark.
Where as the GTX3576R Gen 2 with generic Poncams just wants to keep going. Even at 7500rpm (at lower boost) the power was still climbing to the rev limiter (8000rpm). On the street you would easily get 1bar of positive pressure by 4200rpm and you would happily stretch its legs to 8000rpm giving you a nice 4000rpm to wind out.
Tuning wise, because the torque is quite flat, timing was quite flat too and the VE table also was quite flat, making tuning somewhat much easier than a motor that produces a mountain style torque curve.
Should be good to use the power this weekend at the track, it's been 3 years since I've seen the track.
On 18/06/2020 at 3:17 PM, sneakey pete said:
Will be interested in seeing how the IAT's hold up if you've still got the 76 in there?
Currently have the bok choy dim sum 76mm Hybrid cooler in there.
Did pick up the Plazmaman Pro Series during the week. It's currently still wrapped up, no point throwing it on before the track day as I'm sure the boost control will need to be re-worked.
Makes sense, the drop in response and the stretch up in the rpm could be partly (or likely is partly) to do with the poncams - I remember a mate here with an SS2 ended up feeling doughier down low when he swapped to the poncams, but sounds like he didn't pick up the kind of flow up high that you have when going poncams and GTXG2 (as expected).
Looking forward to seeing how the Plazmaman goes, there could be some real happy wakey uppy goodness to come yet :)
  • 3 months later...
Here's some info for you guys wondering about the GTX3576R gen 2 on a stock bottom end RB26 (Head refreshed).
Mine is single scroll, T3 with .82 housing. Running 272 cams. Made 440kw on E85 - roughly 25 psi or so. Full boost according to tuner is at around 3800-3900 rpm and pulls all the way to redline of 8100rpm.
  • Like 6
Keen to see your real world review after running the twin butt plugs for so long, not to mention the GTX frankenfails. ?
Coming from -9's with all the fruit...
Single FTW - It rips! More power everywhere. Transient response is insane, zero lag between gear shifts, and that's with Kelford 272 long duration cams too!
Even on 98 pump fuel which is about 365kw @20psi it still shits all over the twin -9's.
And the GTX noise is just magic, it's like a HKS T51 ?
  • Like 5
  • Haha 1
Congrats on the new setup and the improved drivability mate. Got a graph?
I dont wanna do it..........BUUUUT.......
WE TOLD YA SO!!!!!! ?
  • Haha 1
Here ya go.
  • Like 3
  • Thanks 1
I still don't get why more people don't run the GTX3576R and still prefer to get a GTX307R. Two real world results on this forum, two happy(ish) Skyline owners.
One has a working car, one has just seized his motor from oil starvation on the track ?
Because it’s all about the compressor. The turbine side isn’t a consideration it seems. “750 hp” compressor, doesn’t matter if it can’t get out. ??
  • Haha 1
I was a click away from buying a GTX3582 gen 2, but glad i spoke with you before purchasing. 3576 is exactly the power band, response and drivability i was after in a street car in the 400-450kw range.
Edited by djvoodoo
  • Like 1
Oooo relevant discussion to what I'm considering for my build!
Im considering a GTX3576R vs a GTX3582R for my full time track car. I'm also looking to be in the 400-450rwkw range, although for longevity of the drive train and likely undersizing of my plumbs,  I'll be looking at operating primarily under 400kw with the option of turning it up on game day when I've decided its power and not driver skill that is holding me back ?
Normally I would look at these results and say it looks like the 3576R is going to give me exactly what I'm after, but what complicates it for me is 2 things:
1. Dedicated track car vs results on a street car. Considering my car is going to be living in the upper rev range, would it be better to go with the bigger housing for the same power in an attempt to help the turbo breathe, or is that just a waste of usable power band?
2. 10:1 compression ratio. I'm bumping the compression up for my build rather than dropping it down, but what does that mean as a consequence for turbo selection?
At least initially, cams are going to be baby Tomei 264's because that is what is already in there and there's no funds to upgrade in that field yet. Perhaps later I will pull the head off again and go to a 272 or something more suited to track work, but I also dont mind sacrificing a bit of top end considering I'll probably have more power than I use anyway.
  • Like 1
I would say a GTX3576R Gen 2 going past 450rwkW is a walk in the park with a well thought out head.
Being a track car, I personally would want a wide power band and run a slightly taller diff to really stretch out the gears. Imagine going through fish hook at Wakefield in 2nd without lighting up the tyres and following that through.
I know going around that in 3rd is just a bit sad in a high powered RB haha.
The 10:1 would definitely give you a meaty power band so perhaps a GTX3582R in twin scroll dis dat could be a potent mix
I'm sort of committed to single scroll now. I thought long and hard about twin scroll, but decided against it in the end when I bought the manifold. If I was going to do twin scroll, I wanted twin gates rather than the divided plumbing from the manifold, but decided the extra heat, packaging and point of failure were issues for me.
You make a good point with the diff ratio though. At the moment the diff is stock, and I know it's going to be wayyy too short for the power I'm aiming for around Barbagallo, I'll be on limiter in 4th or having to go to 5th for half of the straights, which is where you lose seconds. So I know I need to go taller, and hadnt really thought about that with picking a turbo.
  • Like 1
I think 3.9 is perfect in terms of ratios, you can find the crown & pinon from a S15 Turbo Automatic, as I believe the R34 GT-t diff is a touch longer than the normal non ABS R200 diff.
With my limited research the C&P from a S15, R34 and R33 ABS "should" be interchangeable.
I know a hack driver that races a skyline with an rb25 poncams and manual that has done a few 59s around barbs
He has done it with a 3076 gen 1 and 3582 gen II at around that power mark.... he would chose the 3576 gen II for balance of response and power
He did it with a 4.3 diff ratio (but 4.11 or 3.9 prob better) and only had 7 gear changes the whole lap and a setup that everyone called shit ?
Or you should buy his 3582 gen II and he gets a bigger one ?
Edited by bcozican
  • Like 1
Oooo, valuable information, I wish I knew who you were referring to so I could have a conversation. Sounds like he should be in the low 57's really ??
If you'd opened with the "buy my 3582 gen II" bit, you wouldve had me, but you talked yourself out of a sale first! ? seriously though, have actually wanted to talk to you about a few things on your car that I haven't been involved with, so remind me to do that when you're visiting. When is that happening again? ??
  • Haha 1
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
    • The stock manifold is "mostly" divided. The divider actually has a notch cut out of it where it would meet the divider on a twin scroll housing. I have no idea why. But whatever the reason, it would cause some cross talk when used with a twin scroll housing. People do put twin scroll housings onto that manifold. But I'm of the opinion that proper twin scroll internal gating is...not really possible at this scale. You'd be throwing good effort (ie $$) after bad, when you really should be doing something else. Notwithstanding that.... I am not sure what the idea that you are floating has to do with the difference in comp cover position caused by the highflow using a shorter length core than the stock Hitachi one. Can you clarify what you meant?
    • Majority of regulars are > 30. We all act at least 50. Definitely not friendly as we're all grumpy. 😛
