The Old ATR43SS2 (Circa 2016) was a bit more urgent to drive, however it's a bit harder to compare as the motor had stock cams and power would nose over about the 6500rpm mark.
Where as the GTX3576R Gen 2 with generic Poncams just wants to keep going. Even at 7500rpm (at lower boost) the power was still climbing to the rev limiter (8000rpm). On the street you would easily get 1bar of positive pressure by 4200rpm and you would happily stretch its legs to 8000rpm giving you a nice 4000rpm to wind out.
Tuning wise, because the torque is quite flat, timing was quite flat too and the VE table also was quite flat, making tuning somewhat much easier than a motor that produces a mountain style torque curve.
Should be good to use the power this weekend at the track, it's been 3 years since I've seen the track.
On 18/06/2020 at 3:17 PM, sneakey pete said:
Will be interested in seeing how the IAT's hold up if you've still got the 76 in there?
Currently have the bok choy dim sum 76mm Hybrid cooler in there.
Did pick up the Plazmaman Pro Series during the week. It's currently still wrapped up, no point throwing it on before the track day as I'm sure the boost control will need to be re-worked.
Makes sense, the drop in response and the stretch up in the rpm could be partly (or likely is partly) to do with the poncams - I remember a mate here with an SS2 ended up feeling doughier down low when he swapped to the poncams, but sounds like he didn't pick up the kind of flow up high that you have when going poncams and GTXG2 (as expected).
Looking forward to seeing how the Plazmaman goes, there could be some real happy wakey uppy goodness to come yet :)
  • 3 months later...
Here's some info for you guys wondering about the GTX3576R gen 2 on a stock bottom end RB26 (Head refreshed).
Mine is single scroll, T3 with .82 housing. Running 272 cams. Made 440kw on E85 - roughly 25 psi or so. Full boost according to tuner is at around 3800-3900 rpm and pulls all the way to redline of 8100rpm.
  • Like 6
Keen to see your real world review after running the twin butt plugs for so long, not to mention the GTX frankenfails. ?
Coming from -9's with all the fruit...
Single FTW - It rips! More power everywhere. Transient response is insane, zero lag between gear shifts, and that's with Kelford 272 long duration cams too!
Even on 98 pump fuel which is about 365kw @20psi it still shits all over the twin -9's.
And the GTX noise is just magic, it's like a HKS T51 ?
  • Like 5
  • Haha 1
Congrats on the new setup and the improved drivability mate. Got a graph?
I dont wanna do it..........BUUUUT.......
WE TOLD YA SO!!!!!! ?
  • Haha 1
Here ya go.
  • Like 3
  • Thanks 1
I still don't get why more people don't run the GTX3576R and still prefer to get a GTX307R. Two real world results on this forum, two happy(ish) Skyline owners.
One has a working car, one has just seized his motor from oil starvation on the track ?
Because it’s all about the compressor. The turbine side isn’t a consideration it seems. “750 hp” compressor, doesn’t matter if it can’t get out. ??
  • Haha 1
I was a click away from buying a GTX3582 gen 2, but glad i spoke with you before purchasing. 3576 is exactly the power band, response and drivability i was after in a street car in the 400-450kw range.
Edited by djvoodoo
  • Like 1
Oooo relevant discussion to what I'm considering for my build!
Im considering a GTX3576R vs a GTX3582R for my full time track car. I'm also looking to be in the 400-450rwkw range, although for longevity of the drive train and likely undersizing of my plumbs,  I'll be looking at operating primarily under 400kw with the option of turning it up on game day when I've decided its power and not driver skill that is holding me back ?
Normally I would look at these results and say it looks like the 3576R is going to give me exactly what I'm after, but what complicates it for me is 2 things:
1. Dedicated track car vs results on a street car. Considering my car is going to be living in the upper rev range, would it be better to go with the bigger housing for the same power in an attempt to help the turbo breathe, or is that just a waste of usable power band?
2. 10:1 compression ratio. I'm bumping the compression up for my build rather than dropping it down, but what does that mean as a consequence for turbo selection?
At least initially, cams are going to be baby Tomei 264's because that is what is already in there and there's no funds to upgrade in that field yet. Perhaps later I will pull the head off again and go to a 272 or something more suited to track work, but I also dont mind sacrificing a bit of top end considering I'll probably have more power than I use anyway.
  • Like 1
I would say a GTX3576R Gen 2 going past 450rwkW is a walk in the park with a well thought out head.
Being a track car, I personally would want a wide power band and run a slightly taller diff to really stretch out the gears. Imagine going through fish hook at Wakefield in 2nd without lighting up the tyres and following that through.
I know going around that in 3rd is just a bit sad in a high powered RB haha.
The 10:1 would definitely give you a meaty power band so perhaps a GTX3582R in twin scroll dis dat could be a potent mix
I'm sort of committed to single scroll now. I thought long and hard about twin scroll, but decided against it in the end when I bought the manifold. If I was going to do twin scroll, I wanted twin gates rather than the divided plumbing from the manifold, but decided the extra heat, packaging and point of failure were issues for me.
You make a good point with the diff ratio though. At the moment the diff is stock, and I know it's going to be wayyy too short for the power I'm aiming for around Barbagallo, I'll be on limiter in 4th or having to go to 5th for half of the straights, which is where you lose seconds. So I know I need to go taller, and hadnt really thought about that with picking a turbo.
  • Like 1
I think 3.9 is perfect in terms of ratios, you can find the crown & pinon from a S15 Turbo Automatic, as I believe the R34 GT-t diff is a touch longer than the normal non ABS R200 diff.
With my limited research the C&P from a S15, R34 and R33 ABS "should" be interchangeable.
I know a hack driver that races a skyline with an rb25 poncams and manual that has done a few 59s around barbs
He has done it with a 3076 gen 1 and 3582 gen II at around that power mark.... he would chose the 3576 gen II for balance of response and power
He did it with a 4.3 diff ratio (but 4.11 or 3.9 prob better) and only had 7 gear changes the whole lap and a setup that everyone called shit ?
Or you should buy his 3582 gen II and he gets a bigger one ?
Edited by bcozican
  • Like 1
Oooo, valuable information, I wish I knew who you were referring to so I could have a conversation. Sounds like he should be in the low 57's really ??
If you'd opened with the "buy my 3582 gen II" bit, you wouldve had me, but you talked yourself out of a sale first! ? seriously though, have actually wanted to talk to you about a few things on your car that I haven't been involved with, so remind me to do that when you're visiting. When is that happening again? ??
  • Haha 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
