G'day, thought I'd add my two cents on a few of the points raised.
Just to clarify, 50:50 water meth mix does burn, whether you mixed it by weight or by volume. I conducted this test recently and was surprised by the results.
If you plan on tuning the car to be water  meth dependant, make sure you have some kind of fail safe. I have done a number of setups using various brands of ecus, including Link. I usually use the 0-5v input from the flow sensor to activate overlay ignition table and fuel trim. If the voltage goes over or under a set window, due to a flow fault, it will deactivate the overlay tables, keeping the engine safe. I have only set done this up using Aquamist systems so I'm not sure if the system you are using has this capability.
Cheers.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7902951
How did you test that? When I did it no way would it light. I used a spray bottle onto a flame and it always put it out.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7902957
I tested it with 100ml of 50 50 by weight and again by mass. Poured them into small containers and lit them up.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7902963
A pool fire is a different thing.  The fame you bring to the surface heats the liquid, evaporating some methanol, which burns in the vapour phase on top of the pool.
A spray of 50:50 stands a good chance of smothering another flame, because there is so much ability for the spray's latent heat of evaporation to steal more heat than the flame can maintain.
/rocket science.
  • Like 3
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7902976
16 minutes ago, drifter17a said:
my bloody water pipe keeps popping out of the nozzle.
I have made sure the head is round and it is firmly pushed into the pneumatic head.
Could it be cable needs to have more loose section as vibration could be pulling it out ?
Could be. Those aem nozzles use a 1/4" push fit, what diameter tube are you using? 6mm tube fits and will pretty much fall out.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7903117
This might sound a bit stupid, but why do you need water / methanol injection to cool your charge unless your intercooler setup is garbage ? Plenty of 600 -700 Aussie kw at wheels setups without the need for it.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7903306
I know
my intercooler is blitz so i would have hoped it is well known
can’t get hold of my tuner to confirm how car has been setup but very strange as at times it boosts to 17.2 psi and at times 15
Almost always boosts to 17 on cold but as soon as warm it is hit and miss so unsure of what it is
i assumed he is using air intake temp to control boost so using water injection to cool the temp
anyway engine runs better with cooler temp
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7903308
I run a Blitz LM spec 100mm on my 33 Gtr. 98 unleaded, 330kw at wheels, 22psi, HKS GT-SS turbos, stock radiator, stock thermostat, 700cc injectors, power fc, nismo 280l/hr fuel pump,  stock gtr intercooler piping, stock long engine. Just had hottest summer here with temps over 45 deg C for 4 months, no dramas. Something else is up with your setup.
Something tells me maybe you don't have what you think you have as the Blitz 100mm LM intercooler has less than 1 psi pressure drop at 1.5bar / 22 psi across core and cools enough for stupid hp.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7903320
11 hours ago, drifter17a said:
I know
7 hours ago, BK said:
Don't worry about contacting your tuner. Get on this forum
https://www.gtr.co.uk/forum/
and ask around for a tuner near you who has good knowledge of the RB engines.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7903341
  • 3 weeks later...
Why would your intercooler heat soak on the dyno???  Didn't he have a big MuthaF@#king fan going hard on the front of the car?
WMI is to reduce knock when winding up the boost for more power.  Its a way of extending the mechanics limiting your existing setup.  Its not a bandaid for your problem.
And you probably should have asked on here before buying, the Snow performance Stage !!! and [from what others have said] Aquamist are the better systems because you can progressively add WMI using both vacuum/boost and IDC.
I have set mine to IDC 40% and all in by 70% AND 8psi and all in by 14psi.
Snow Performance sell a very neat solenoid valve for gravity drain.
https://www.sau.com.au/forums/topic/476553-methanol/page/2/#findComment-7904646
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
