You are correct, a loosely thrown around interval is 5000km, but that is largely dependant on the operator. Someone who is very skilled at changing gears in an H pattern dog box will cause little to no wear on the dog teeth faces. Same thing with a sequential with correctly setup strain gauge strategies correctly unloading the gears on shift, very little dog wear will occur. On the flip side someone just bashing a dog box around not shifting correctly will wear the flat sides of the dogs very quickly, to the point where they will jump out of gear on the slightest gear unload. This where km on box is not a good gauge for inspection, rather inspection intervals at X amount of hours, or x number events completed.
You are also correct in the dog gear replacement. The main shaft gears usually have dog teeth on the side an a separate sliding dog that matches to it. What you have to replace can only be determined on a box teardown, so it is not impossible to predict what you're likely to need. Sometimes with only slight wear on the dog teeth you can get prolong the gear or sliding dog needing replacement by regrinding the dog teeth from being rounded off to square again. This will buy you more time with needing to replace anything, but eventually round again and need to be replaced.
The biggest problem is that any of the above requires the box to be removed from the car, disassembled and inspected, possibly repaired, reassembled and reinstalled again - whether you replace anything or not. This is where the main cost in keeping a dog box alive is, not necessarily the cost of any parts that may or may not need to be replaced. When someone chooses to go dog engagement this has to be just accepted as the norm, and is the main reason why a synchro box makes more sense for a dedicated street only car.
  • Like 3
Thanks for the reply !
These guys do a dog box with the rings seperate from the gears - https://www.6xdgearbox.com/
They suggest a dog is $300 ish AUD.
Anything like that available for the GTR ?
info for anyone interested
  • 5 months later...
I have a new Series 3 box, haven't broken anything yet with around 700hp, I go easy into 3rd gear.
Have been tossing up about the sequentials.  Lately the word has been PPG = probably not, a few people who've had them haven't been too satisfied with how they hold up
A few big HP GTRs have switched to Samsonas and handling the power well.   Albins seems quite new to market, unsure how good they are and how they handle the power.
Big money to drop on a gearbox.  I'm tossing up between Samsonas and Albins but will definitely want to know what's got the better track record on holding the power
Edited by RB335
Here's a quote I got for a PAR gear 1-4 straight cut syncro with stock 5th.
Note from the gearbox shop:
"the PAR sets work well with the upgraded 26-spline input shaft. It does require you upgrade your clutch to match with the GM style input splines."
This means new clutch, labour involved to take the box out (if you cant do it yourself), shipping to send the box to the shop (if you don't have a decent gearbox builder in your state) and to send it back. It all adds up quickly.
There's a few guys in WA using PAR gear sets and are very happy with it.
  • Like 1
updates, got my PPG dogbox back drives sooo much better :) after about 500km i can drive it without issues around town all different speeds, best way to explain is it loves direct shifts, it really isnt that bad to drive and i have to say once i got used to it i almost prefer it to a syncro box.
53 minutes ago, Greekos said:
2nd gear, 3/4 inner hub,1/2 outer hub dogs had the gear-set isf refinished, the pressure changing gears is almost like stock, so it was definitely a assembly issue that caused my grief
Do you mind uploading a video here mate?
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
