As the title says iv been in the market for a manual r34 gtt coupe for a few months now. Watching how the market is going im seriously starting to consider buying an auto r34 gtt and then just paying for the conversion (and mechanic labout cost)
The price range between a manual and an auto is insane. Iv been tracking a fairly clean r34 GTT 2 door for a little bit around 14k, however if i wanted to buy a manual version of the car i would be looking at something around 19-20k
Is that big of a price range practical or should i just buy a full conversion kit for around 1800 and pay a mecahnic to swap it for me?
The usual answer is "don't take it on unless you are able to do it yourself". Perhaps that's less so for gearbox conversions than turbo engine swaps, but it's been the usual advice.
However, where there are availability issues and the price difference is that wide, sure it's practical. I did it to my R32 many many many years ago.  It's not difficult, just need all the things and enough skills to make the wiring changes, etc.
If you can do it yourself sure, but you want to be sure of what you're getting in that particularly "Conversion Kit" because $1800 won't get you very far if you're buying all parts brand new.
So yes, but just be careful and mindful that extra costs can pop up, especially if you want to do everything 100%
The conversion cost is about ~1k-1500 for a mechanic to do if for you, so think closer to 3500-4K installed and running.
After that your only issue is the auto steering wheel, but you can always use the buttons to trigger something if you want to get fancy. It is worth doing if you find a really nice auto 34 that is unmolested or has the (other) modifications you are looking at.
There are quite a few conversion threads so go through them and make a list of all the things you will need - many conversion kits do not come with e.g. gear lever (c/w knob and boot) centre console, complete clutch including flywheel, clutch pedal and hydraulics, handbrake, speedo drive,  the list goes on so make sure you write everything down (it will be a long list) and compare it with what you get with the kit. Here they are asking 2,500 to 3,500 for a kit and then you don't always get all that you need. Most importantly make sure its a proper RB25 "big box".
I converted my C34 Stagea because manual ones were/are so rare but if I were you I would keep looking for a manual Skyline.
If you can find a decent auto, i say go for it. Mine was auto and i only coverted to manual 'cos it was time' but i see nothing wrong with going that way - as you say, can be a huge price difference when buying the car in the first place. My conversion kit was 1750aud and i wouldnt have spent anymore than that. By the time you buy a decent new clutch kit, 1piece clutch line, new cylinders etc, better off just getting tailshaft, box and pedals unless you get a cheap full conversion kit.
  • 2 years later...
Do you have links to said parts?  The problem with old forums is there are a bunch a broken links, missing pictures etc.
I recently did a manual swap on my Stagea - here is the guide I used for that and a lot of it is the same for the skyline. Of course any mention of 4WD doesn't relate to you.
I also made a video of the process
  • 4 weeks later...
Question:   I have a R33 GTS-T RB25 automatic in my R34 GT-T.  I also have on the bench... a pull type AWD staega transmission with bad gears, AND a Z32 TT transmission in great shape.    Is it going to even be possible to swap bellhousings from the AWD pull type transmission over to the Z32 and achieve a manual swap?  A spec clutch just came up for grabs, still in package, but I don't know if I can even use it.
Edited by walperstyle
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
    • Oh, you are right. But, in Australia E10 is based on 91RON fuel and ends up being 94RON. Hence it being the cheaper option for economy cars. The more performance oriented cars go for the 98RON fuel that has no ethanol mixed in. The only step up we have left then at some petrol stations is E85.
