Hey - I would look at some old posts but since its 2019 time has moved on so I want to get an up to date opinion.
I am keeping the stock non-Brembo callipers as I use the stock 16" wheels but I need to replace my current pads.
A company in NZ has recommended some new DBA pads and slotted rotors as an upgrade of the stuff that is in there.  I know some old articles had issues with cracking but then I heard the new stuff doesnt crack.
Anyone used it lately and what do people recommend now?
Thanks guys.
https://www.sau.com.au/forums/topic/477319-r32-gtr-non-brembo-brake-upgrade/
I would not use DBA pads, however their rotors are good.
Avoid the T2 junk, get T3 aka DBA4000... also if you don't want rotors to crack don't gets slots.
Slots are a marketing gimmick, also DBA machines them in after production, if they were cast slots then they wouldn't crack as easily.
What's your budget like? Intima are decent pads at a fraction of the cost, Elig pads are a step up, followed by Project Mu (Australian Thailand made ones), followed by Project Mu (Japan, Japanese made ones).
HC800+ is NOT HC+ no matter how much the guys up at Racers Warehouse in QLD say they're the same, they're simply not.
RDA slotted & dimpled better value than DBA.
Intima RS is my preferred pad for street. Note that RS is their "street/track" pad. SS is their "street" pad. RS works very well as a street pad. Also, very good value.
I have no specific knowledge of the DBA pad that you mention.
Check out the Znoelli website
http://www.znoelli.co.nz/
and if you are in Auckland call round. They have a range of rotors (didn't make replacement rings for my D2s at the time) but I have used their high performance pads with success. I don't know how their prices compare these days but worth looking in to...
Braided lines, DBA T3 rotors and Intima SR pads all combine to be a very capable performance / Street packed with excellent pedal feel. If you spend most time on the street then go the SS pas as the SR’ can have some sqeal occasionally.
Edited by Torque Curve
  • Like 3
I run those cheap d1racing slotted rotors and EBC yellowstuff pads and Penrite brake fluid. Zero problems done 5 track days and at 200+ can stand on the brake over and over again no fade driving round town is good as well just have to remember not to stand on them like other cars other wise you bounce to a stop. Good brake fluid makes a word of difference
  • 3 weeks later...
On 27/06/2019 at 10:23 AM, Stixbnr32 said:
yes just got braided lines now.
will find those pads and the discs I got lined up.
Cheers all
Also - how do 245 tyres feel on the 16's are they to big/ballooned?
I've found that the 245 50 R16 Nitto NT01's are just amazing. They are a very stable tyre and offer excellent feel when cornering aggressively, also they fill the guards nicely.
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
