Hi all,
I’m going to purchase a bee r rev limiter but not sure which type to get. There’s type B, type H and Type h2. It’s for my r34 gtt rb25det neo. Nengun says type B but I’d like to confirm that’s the right one for me. Are the 3 different types just for vehicle compatibility or do they all have different features. Also does the bee r have 2 step i.e does it allow you to set two rev limits - one for launch control and the other for when the car is moving? Also, does the gain knob(the yellow one) let you adjust how hard fully sick backfires are spit from the exhaust? The eBay page says OEM catalytic converters won’t produce flames, but would my 3 inch turbo back exhaust?( not sure of brand but definitely not OEM)
also, is the bee r still compatible if I have a apexi power fc comp and hand controller? I read on a couple of forums they have ‘handshaking’ issues
Also, on nengun’s page it says the factory fuel cut limiter is bad for the engine and ignition cut is better, but I heard it’s the other way around from word of mouth, which is true??
Finally, nengun sells them for $340. Is that the price the genuine ones go for because I don’t want to buy a fake one.
I asked too many questions but I highly appreciate the help and responses, many thanks
Edited by IM-32-FK
  • Haha 1
I suggest you get a proper ECU, rather than a Bee*R rev limiter which would eventually blow apart your turbo, drive train and the works.
It's merely a terrible hack/interceptor for bangs and wank.
  • Like 3
I already have a proper ECU - my apexi power fc. But it only has fuel cut and not ignition cut. I want bang and wanks, your warning of f**king the turbo and ‘the works’ is duly noted but I want my fun, but I also want anti lag.
I agree. After you break something, the replacement cost could have been used to buy a modern ECU. Do it once, do it right?
Edited by Murray_Calavera
Your ECU is not proper
Get a Haltech or a Link or an Adaptronic even a Nistune can go bang/wank/pop on launch and controlled too. You're able to set the exact RPM, timing and fuel compensation on launch with the Nistune. The Bee*R junk you cannot.
An ECU is cheaper than a new motor.
  • Like 1
  • 3 weeks later...
Spend the money on a link and look after your car.
Youll still get some naughty 2 step without the damage and the Power FC is very capable but very old.  I just replaced my HKS F-con V Pro so I could have modern features like new trigger setup and E85.  Was gutting to do but needed.
Edited by Stixbnr32
From a PowerFC to a modern ECU, massive difference.
Then throw out the Nissan CAS into the bin for a reluctor setup (cheaper option) and you'll be kicking yourself again. Or just go tits out and get a proper crank trigger setup.
Sorry to hijack
That is what I have done this week full trigger setup and link g4+ with new e85 compat fuel system.
Im no sure what to expect now I thought id just get more power haha.
Edited by Stixbnr32
You don't get more power, what you get is a lot more knowledge about how to make your engine run right. It is a slippery slope, self tuning. You kind of get to the point where you realise everything else was a bit of a half-effort-not-completed job, and its a lot of satisfaction getting things running actually right.
Better ECU's give you better control over what is happening with the engine. Better control = better running engine everywhere, not just WOT pulls from 4500RPM upwards.
  • Like 1
And with better control, and better strategies you can push your engine more (safely).
A F1 motor in the 80s lasted only a few sessions. Take the same motor, with a modern ECU, sensors and injectors you can make it last years.
4 hours ago, Stixbnr32 said:
Sorry to hijack
You will get more power if you run e85 and tune accordingly...
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
