  • 1 month later...
So eventually I made it to the track day! Got my tyres rotated, my brakes on..
Went to setup the gopro and realised I forgot all of it, and spent 6 hours the night before attempting to remember which was fun
Decide don't really need it all to have fun at the track day, and get going.
I had recently supposedly fixed my PCV system, but I had the dipstick getting blown out now which was fun
I did a few sessions, but was 5s slower a lap than last time, which was fun
Then this happened!
Then the tow truck broke down on the 10 minute drive home which was fun.
After researching gearboxes between then and now, it finally came out yesterday. It appears the only way to pull this gearbox out is disconnect it from the bellhousing and take it out that way, with much swearing I am told.
However this is what was found.
63700666_1380aed4-be17-40a6-8e5c-1467b5d02c81(1).jpg.90d50081e7fc082cd67e17d03ef5f578.jpg
fun.
  • Confused 1
  • Sad 1
ha, I've done something similar in an evo, sheared all the rivets off so the centre and the plate could turn independently.
Kind of hard to diagnose without taking it apart, but it is nice when the problem is cheaper and easier than it sounds :)
  • 4 months later...
SO
This has been off the road since January, due to delays with replacing various items. In short, I decided that instead of replacing only the clutch, I'd replace the gearbox as well (previous gearbox was fine) because I didn't want to be in this position again any time soon.
Also the T56 Magnum is a massive step up over the regular T56 in every single way, especially for driving and shift quality which is actually a bit of a big deal for me...
On that subject though, the post mortem on the clutch came back when the new box was going in, because the slave cyl didn't have nearly enough room to do it's job due to the starter motor relocation kit/spacer that was in the bellhousing. In short, my old clutch was never fully disengaging - Which is the likely culprit of the early failure.
This was machined up to fix this problem, to give the moving bits enough room to move to do their moving bits job.
It took awhile, but I did receive a T56 Magnum from Mal Wood, with his short shifter, and a rear case (from what I assume is actually a FG Falcon) because it has a Falcon FG short shifter on it.
The idea behind this was to extend the rear case, so that I wouldn't have to use a dogleg shifter handle, and could use a handle that was straight up.
Measurement.thumb.jpg.3dd4fed5e4e261a9dcfb3fb0d51d4f07.jpg1231290581_MagnumtosuitVT2toVE.thumb.JPG.ea3f1e5b6bee3cbaa6bceaccb8677b95.JPG8b627454-ae28-4d19-b342-56be25595c71.thumb.jpg.673123c9524451973ee0e40c20cc2327.jpgfa771c61-ede5-42ea-9fa9-bafb96c3e91c.thumb.jpg.b0a12aee1c5b5e522e17673d3f2348f4.jpg47cadd8a-d8aa-4c2f-8d40-27d15f665631.thumb.jpg.b581f78d25e7c25f88094e1bbf7585e9.jpg
I also opted for his Model 3 inter clutch, which will do more than enough to hold the power given it'll actually disengage. The only criticism I read of this was "It drives too much like a stock car, I want a heavier clutch so I feel like I am driving an actual modified powerful car" (again on Ford forums).
So yeah hopefully this will suit!
I also bought a metric ton of heat shielding, namely this stuff.
Header Heat Shield - Lava Armor Exhaust Shield | Heatshield Products
And this stuff, for the rest of the exhaust
Heat Shield Material - Exhaust Heat Shield | Heatshield Products
a99a84b0-4423-4f0a-b83e-44145a446ba1.thumb.jpg.5cd513adf218b890b6d6b0621584df30.jpg03a2fbe4-e61a-49e3-ada6-32cecb96ecc5.thumb.jpg.47c90caa06d176b6234fc8ffd2b4c60f.jpg5b80cf72-3123-4309-8112-25cd2f54892d.thumb.jpg.6943f36e000bfde954073b710cd7481b.jpg309a202b-6384-4b4a-8ca7-1b2023e0f78b.thumb.jpg.d95fa89d758c8f0a817ddb6f1248fa3b.jpg203506754_822661568678474_6299047695234846216_n.thumb.jpg.30243b5aad6d141bbf536a1716012adf.jpg205551035_494473614947854_2356513534173637340_n.thumb.jpg.14270d154826027a139cfb9542edc1ef.jpg2023532498_201686843_401836237800146_108579719473083281_n(1).thumb.jpg.7eaa3b1704c7ad6aada47f25b24b7bcf.jpg202823975_328962758900126_9191313222138732063_n.thumb.jpg.bbe2a2dcb1bdd33c72c57f5627d792e5.jpg
And here photo sof it on the headers and pipes and such.
I really hate overheating, I was hoping new fans (from a later Mondeo) and absolutely lowering engine bay temperatures may help with giving the cooling system less to do. I also really want to limit heat getting into the car from the exhaust (can you tell?)
I have since learned since ordering this stuff that a better bet would be to remove my 25% underdrive pulley that came with the motor, given it is only running the water pump at 75% capacity. Given my issues only occur when I am at idle, on 35+ days, with the aircon on, for extended periods... having 25% more water pump seems like a more sensible idea.
Also noting that:
ATI make a 25% underdriven dampener, but don't recommend anyone use it
ATI make a stock size dampener, that actually provides dampening (my 25% UDP pulley has no such dampening)
GM use ATI dampeners on their own crate performance engines instead of a GM OEM item.
The gain in using a 25% underdriven balancer is about 5-10hp.
So yeah, it seems like a much more sensible idea to get the dampener that actually provides dampening on a notoriously non-balanced motor, then underdrive the alternator and look into a better power steering pump for track use, which are all widely available.
So that'll be next, once all the stuff in this post is up and driving again, pending a new driveshaft for the new gearbox, which literally was handed to the guy to make up on his last day before retirement.
What could possibly go wrong with that?
  • Like 2
I haven't - But my power steering I have noticed is not actually the LS1 model that everyone complains is shit/overheats/leaks from every orofice.
I dont know if I haven't had problems due to the fact it was previously underdriven 25%.... now that it is driven at normal rate it could be more of a problem, and it may be less heavy! I'll have to wait and see. They also sell a 150mm pulley, the stock/spare one I have is 137mm. I assume* the one on the car is also 137mm. OEM reservoirs have a filter in them and are pretty damn cheap to replace, if that starts leaking. Seems a better option than the alloy res everyone seems to upgrade to.
My pump is actually the VZ/VE pump, and I'm not often at full lock at full RPM. However that looks like a potential little side project down the way, other than letting go of the purity of hydraulic power steering of course!
On 7/23/2021 at 10:39 AM, GTSBoy said:
It's still hydraulic. The pump is electric. Just the mechanical power to run the pump goes via the alternator instead of the PS pump belt.
This is both news and makes sense to me. What I can't find is anyone saying anything about how the steering feels any different afterwards. I guess it would help with RPM based problems assuming the Astra pump is driven steadily and not RPM dependent.
I.e in the future I will almost certainly try this cause...reasons....
(the reason will be something broke)
On 7/22/2021 at 2:25 PM, Kinkstaah said:
218210646_344139437294988_8631301647606397432_n.thumb.jpg.b3d4bc4bc840914b56de955d02e213d9.jpg
Oooh it's happening!
Turns out this is not happening, because when going onto the car.. this is a LS1 Corvette balancer, not the Commodore one I called about to confirm it was 100% the right fitment before ordering.
Whoopsie.
Left = Old LS1 25% UDP balancer
Mid = 6.0 LS2 balancer
Right = My now on the way back to the supplier Corvette LS1 balancer.
  • Sad 1
I still await Startrack for my Balancer.
In the meantime, my lovely girlfriend sold her Turbo MX5.
Her criteria was "Something Japanese, Fun, but a hatchback" (cause she doesnt like 100kmh highways in a MX5, and tends to go to bunnings a lot)
Basically my Megane, but Japanese. Because she is blessed, not cursed, this is now in the driveway, 1 day later.
226593752_343409903943496_7939679353910184319_n.thumb.jpg.23044884cd4d70a6f99d8defe50c5274.jpg226224156_376025537291074_3328260243857776402_n.thumb.jpg.a4a552411c4767737fa7e4f7eb72a0e7.jpg225272948_571323400973126_7774757779284304047_n.thumb.jpg.85c73faff3e647454c9ece30ddba38a3.jpg224994218_4379476135450455_3679788787422694318_n.thumb.jpg.ea306a29956328f55012d00c169ab39e.jpg224960145_162759729256758_1130167335309317806_n.thumb.jpg.dc9ea0aed84321b01ff26ddaaec15865.jpg224649383_977659806416484_6636536901357363427_n.thumb.jpg.f29138ccde4189da621ba0d3ecaa9dd5.jpg224230069_549070822802896_6862671630007458748_n.thumb.jpg.5e60d487abed2d599ac952d6c156a973.jpg223947503_330528735479892_3067472748017083202_n.thumb.jpg.e1d096ff70deabb3e1a07a1ed1846273.jpg223498480_2966969933576851_2983102432087701973_n.thumb.jpg.1ad005d4d9831ecf5b0f1c59ae73b1f7.jpg223475056_3074708889417871_3420927649355323688_n.thumb.jpg.b218d782ddff5f4b4866ede58b0868e5.jpg222445654_2661993264099639_8515270279026399300_n.thumb.jpg.8ab329fbe6e7263ebd0e20c762d71781.jpg221871859_366257114935893_7839509471255955071_n.thumb.jpg.a5db7aa490defd1d81f7e9008beb019b.jpg221707052_177457567709590_3834336054714403583_n.thumb.jpg.29fab33bbcf0fecc7c89a51f58c5ebac.jpg221478104_199821855424294_4034773256074492794_n.thumb.jpg.62f8b53bea20c409db7f2da07881bef8.jpg221068394_561674381911864_5020838584649038203_n.thumb.jpg.c2d74dc76842a1e82ae44b4b489bd9e2.jpg226785789_584466939208590_5773970689106440713_n.thumb.jpg.66cfdc6705a02a8f7565d6cee9e26161.jpg
Bonus Extras (that she and seller didn't notice, but I did)
Genuine P1 Buddy Clubs
Genuine Mugen Wang
Short shifter of some sort (shifts amazingly, def not stock - we test drove a few cars)
Aftermarket Helical LSD (Quaife?)
One of the other ones we tested had an Intake, for max VTEC sounds. So we're getting one of those.
As for how it drives, I have now experienced 3 different cars in this household I should primarily drive around instead of my R34. I googled bolt on supercharger kits for the K20, which was the inspiration for my mate's supercharged BMW, and found that when I overlaid a video of someone doing a 50-250kmh pull, and my own video at Sandown in the LS Skyline... they were identical in acceleration.
Every frame of the entire thing. It was eerie.
My lovely gf is extremely happy, and I am too. They really do drive excellently, and the fit and finish and interior is just awesome. I am more excited to drive this thing around than my own car, which I hope to high heaven is just because it's new to me and a great deal/hilariously good buy.
However this completes our household change from Turbo life to N/A Purity!
  • Like 2
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
    • To re-cap, I bought: https://www.alibaba.com/product-detail/Lsailt-8G-Infiniti-Q50-Q60-2014_1601171829627.html?spm=a2756.trade-list-buyer.0.0.2cd476e9FTIlKE As you can see, if I bought 20 it was $653, but I bought 1 so it was $1,170. I was very tempted to buy 2 and resell 1 at 25% cheaper. @MBS206, I am not sure if they do a Kluger one, here is their list but it might be there under a global model name: http://www.lsailt.com/product/android-interface?page=1 Keep in mind these full android replacements have basically all the bits a phone does (cpu, ram, storage, wifi, bluetooth, usb interfaces) other than a screen (it uses a host), thus the $800+ cost. Android Auto screen mirroring is MUCH cheaper as it's just a cut down shell, input mirroring and output mirroring BTW I also need that "screen off" feature, it is much harder to see wildlife even if a dash is reasonably dark. Both the Fuga and V37 have display off buttons for night use, they just come back on for a second or 3 if you interact with it, eg skip a song.
