1 minute ago, hattori hanzo said:
re exhaust, bigger is always better
See below graph of cutting the restriction out of my HKS Hi Power Silent
Will decide very soon!
awesome results man👌
yeah when i ditched my 3.5 and went to the 4" my egt's were much lower during hard driving, and recovery time was much better for egt as well. holds boost better in top end with my twins but wont notice that with that beefy Garrett, she gunna pull like a maniac either way....
  • Like 1
Update:
-Fuel tank is in with the frenchies kit and the fuel lines are completed
-cooler pipes, catch can and pod filter pipe is all painted in gloss black for that clean blackish look
Edited by oktaytrz
Wrong picture
More progress shots.
Whats left:
-Finish off the exhaust (trying to decide what muffler to use)
-Order Bosch 1650cc
-Install the hicas delete kit
-Replace all the fluids
-First Start
  • Like 1
Update
Muffler is manufactured and sent to Perth.
Next week we will be replacing all the fluids, installing the Red Optima battery and the muffler. First start is expected end of next week or early December.
On 17/11/2020 at 12:17 PM, oktaytrz said:
Is there a reason that the bov is pre intercooler and far away from your throttles ? It's also seems unnecessarily long and close to your wheel.
Bov is supposed to be mounted as close as practical to your throttle body, that's why the OEM put them where they are.
Your muffler also looks smaller than 3.5inch internally
  • Like 1
2 reasons: Placing the BOV near the turbo is to prevent compressor surge and we thought, if we ever need to go to engineering (if I get yellow stickered etc.) and plumb back, its a lot easier to plumb it back on the passenger side.
Here's another photo from another angle. its pretty far away from the wheel.
1 hour ago, BK said:
Boost control = wastegate via solenoid.
We are using the haltech boost control solenoid. I'm leaving the nitty gritty stuff in the hands of my very capable mechanic haha.
Excited for the first start up on Monday!
38 minutes ago, AgEr said:
Hey mate...just checked out this thread... nice build, your gonna love it. I got my car back a couple of weeks ago, running a similar setup. Made 450kw on pump and 550kw on e85.
Hi mate,
Thars great! How much boost you pushing through? 550kw is amazing! I'll be happy with 475kw!
Did you have to run in your engine for a bit?
48 minutes ago, oktaytrz said:
Hi mate,
My engine was already previously built.. just done the single turbo setup and some further supporting mods... 19psi on pump and 21psi on e85... if you haven't finished your exhaust, I would recommend getting an AES dump valve... easy power gains when open and it makes it sound like a monster with the flick of a switch...
  • 4 weeks later...
hey man sorry I've been away from the site for a bit. super happy for you mate. good guy even better car lol. side not I got my new rb26 finally stripped to long block and ready to ship for machining and building. ill pm you. engine looks great though man mate what a beast. the old white horse is gunna buck lol
  • Like 1
  • 5 weeks later...
UPDATE:
Its been a while.. started working FIFO so things are moving a little slow.
Still waiting for the paint prep to be completed before the respray. In the mean time we have an issue to solve which I think its the Gearbox input shaft. There's a rattling noise coming but couldnt not figure out the exact location. The tuner and my mechanic's first guess was the alternator bearing but we've started the car without the belt and the rattling was still there.
When the clutch is pressed in, the rattling goes away and the usual twin plate clutch noise comes which isn't too loud.  Due to be back home next Friday so I will be dropping the gearbox out, leave flywheel on, bolt up the bell housing/plug the starter and start the car to confirm its the gearbox.
Overall, very happy how the car turned out mechanically but I will be doing some more upgrades during the year so watch this space!
38 minutes ago, hattori hanzo said:
Did i miss something, how did it go on the dyno?
Running Tune went pretty good mate. The car drives pretty good, its just that rattling noise that I have to figure out (I put my bet towards the gearbox input shaft).
The only issue with dyno was the exhaust side of the engine bay paint lifting/burning off due to me not having a turbo beanie +reflective tape along that side of the engine bay lol. Turbo sits too close towards the engine LHS engine bay. Will fix that after the exterior paint is completed.
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
