yeah it is...the third largest connector is the one your looking at, remove it and measure for continuity between terminals 13,14,15,16,17,18,19,20 between .8 and 2.2, the terminals you are focusing on are in pattern. remember you are measuring the harness side not the atessa control unit side. if you have continuity between the connector terminals you need a new control unit. if you don't have continuity you need to measure resistance at terminals 1 2 3 and 4.  this will narrow it down for you without doing any wrenching at all.
@MoMnDadGTR
So this is my results
13 though to 20 is no continuity
So I tested 1 2 3 4
2 and 4 gives me 130
3 And 4 is contunious
2 and 3 gives me 115
I'm so confused how should the numbers be
You're not supposed to test all of them to all of them. The original linked document clearly says check 13-14, 15-16, 17-18, 19-20.
Expected resistance is between 800 - 2000 ohm.
You do not do this with the multimeter set to continuity. You do it with it set to the appropriate resistance range. Which will either be 2k or 20 k. Try 20k first, as raw accuracy is not important here.
If the circuit is open (infinite resistance) then you have a broken wire, dud sensor, something like that. If the resistance is drastically low, it's either a wiring short or a dud sensor.
You can see the difference between harness faults and sensor faults by measuring at the sensors, as shown in the diagnosis tree.
  • Like 1
@GTSBoy
I just want to clarify I have tested
13 to 14 15 to 16 and so on with my tester. There is no continuity.
So my next step would be to test the terminal 1 2 3 and 4. Can you confirm this is correct
There's not supposed to be "continuity" in the sense of a short circuit. The resistance across those pairs of wires is supposed to be between 800 and 2200 ohms. As measured with the multimeter set to the appropriate resistance scale, probably 20k ohms.
29 minutes ago, Semih_Ozdemir said:
The meter I've got is a fluke multimeter.
It hasn't got the setting to change over to 20k ohm etc.
This cannot be true. The very definition of a multimeter means that it can measure resistance. Fluke is the best brand out there. It is not possible that it doesn't have it.
The red arrow shows you the resistance mode. Flukes are autoranging, so you don't even need to select the 20k range yourself. It will do it for you.
correct the multi meter has to have the setting on it looks like a horse shoe. I also can add that when testing for resistance make dam sure you have a good connection in the terminal with a nice sharp end, sometimes you can tie a paper clip to the end of your multimeter probe to get a better connection in the terminal. this is sounding like bad ground, broken wire, something to do with the relocation I believe. let us know when you have done the resistance test on terminals 13-20. then we can narrow down if you need a new control unit or if we need to continue testing
ive always stayed away from relocations and what not to keep diagnostics easier and what not just keeping a simple fast platform. I do feel once the multimeter and you become friends your gunna solve this issue quick.
Okay @GTSBoy I've got a fluke clamp meter. My bad. It only measures continuity and not resistance eith a scale.
@MoMnDadGTR
I've got 2 sensors of a mate. I'm just going to replace the front right sensor and see if that fixes my issue
No. Swaptronics is the last resort, not the first.
A useful multimeter is $10 at Jaycar.
What model? I've never seen one that doesn't do resistance, current, volts, etc.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
