Hi All,
Been a while since i was on here and in a skyline, but im pleased to say that im now the proud owner of this R32 engineered with an RB25DET NEO and heaps of fruit!
Spec is as follows:-
Engine & Drivetrain:-
105,000km’s
Engineered 365kw Rb25det neo
Set up with Boost by gear. As follows
18psi 1st, 2nd and 25psi 3rd, 4th, 5th on e85
18psi on 98
Gtx 3076 .82r garrett with speedflow fittings and braided lines
ATP catch can with speedflow -10 braided lines and fittings
50mm gen V turbosmart external waste gate
Spitfire coils
Custom 3 inch dump into 4 inch HKS exhaust
ARP head studs
Bosch 1250cc injectors
Turbosmart fuel reg
Turbosmart fuel filter
Walbro 460l fuel pump with relay
Haltech elite 2500
49mm Koyo type r copper radiator
Brand new Rb25 gearbox, exedy sports tuff HD clutch with upgraded pressure plate and one piece tailshaft
4.3 diff gears 1.5 way nismo diff
Interior:-
Haltech racepack street dash
Aem oil pressure gauge
Aem wideband
Turbo smart boost gauge on pillar
Suspension & Handling:-
Cusco street zero adjustable coilovers
R33 Front lower control arms
Adjustable castor rods
Exterior:-
Genuine N1 headlights
Genuine GTR bonnet,
Genuine GTR front bar
Genuine GTR grill
Genuine 17x9 3 Piece BBS LMs wrapped in Hankook rs4s
ICE:-
Alpine Double DIN Headunit
Kicker Amp
Kicker 6x9's
Kicker Front Speakers c/w tweeters and crossovers
Current plans are:-
raise it up a little bit 10-15mm
remove some camber from the front,
buy some new rear tyres
wire up the wipers
carbon front lip (to replace the flaking stock one)
enjoy driving it!!
Now for the pictures!
IMG_5467.thumb.jpg.5a7804f035bcae31715eac2a0dbff4da.jpgIMG_5466.thumb.jpg.9d0208a0fc25dd8778fe51f07209a8cd.jpgIMG_5470.thumb.jpg.44cbff3d2e264a3307b786ba1e5447b2.jpgIMG_5461.thumb.jpg.28972758ed90935ef0a1e91228e18969.jpgIMG_5426.thumb.jpg.b76e40f0b75afbb0f4793eefb2191c2c.jpgIMG_5425.thumb.jpg.d8dddd384b338d39ed4901f15f86944f.jpgIMG_5420.jpg.824a798f4d158e3692656945659dad1d.jpgIMG_5468.thumb.jpg.82d9026481672937710d2973f055ab02.jpgIMG_5474.thumb.jpg.35edee158d92a8dc7bbc8409a59a5470.jpgIMG_5476.thumb.jpg.101dfd55b84756042f82d7773af60af0.jpgIMG_5441.thumb.jpg.0c74f306198e0c64c87565d81cdbde06.jpg
  • Like 3
https://www.sau.com.au/forums/topic/480029-daymos-back-r32-rb25det-neo/
Thanks, yes it was definitely well loved!
The previous owner put all the stickers all ver the car, i've removed most of them from the windscreen, i didnt actually know thats what the sticker meant on the ashtray, might leave it there now i know!
thanks! yeah as soon as  i saw it i just had to have it. it was basically what i dreamt i was going to do with my last one but without all the hassle and its already engineered!
I'll definitely be in touch when it comes to ordering some new pads!
yeah theres just a few little bits that need finishing off.
The wipers are not wired in - i luckily have an old rb25 loom in my garage that i can unpick the plug from. but its still gonna be a bit of a task. and i absolutely despise wiring!
Also need to put the washer bottle back in once he sends me it. hopefully all that wiring is present.
Horn doesnt work either, again hopefully thats a simple fix. just want to make sure all these issues are fixed and keep it properly roadworthy.
Will need to make an enclosure for the pod filter too, thats the fun part though. means i can practice my welding skills on scrap stainless from work :)
Put the 3D printer to good use and printed this cup holder out of ABS. Gonna change the design a bit and get rid of the GTR logo and make the fit a bit smoother across the top. But it works for now!BD9F8CED-E4D3-48E4-894D-001FDBC871F2.thumb.jpeg.34c73a24dab8bac9f6bb378cb6125338.jpeg81FF9B4D-9A62-4801-879E-4C835B0F09F1.thumb.jpeg.86d27a8305b4e0778bb3d003ff2957dc.jpeg
Spent an hour or so unpicking 5-6 wires from an old rb25 wiring loom I had lying around. Tesa taped them up and found the connectors in the existing wiring loom and hooked them up. I now have working wipers! That’s one less thing to worry about come rego time!
Attempted to take the rear wiper off but the nut is all rusted out and corroded. Going to try and weld some scrap metal too it so that I can undo it and remove the whole motor assembly. Will use one of the blanking plugs from the boot floor so I’m not left with a hole in the glass.
Will 3D print some new bungs to fill the holes in the boot floor and stop water getting in.9F9B89EF-B2B2-4364-A7AA-4A6385168CB7.thumb.jpeg.a028aa2a22ef548f04cf1565e8ae2200.jpeg
Edited by DaymoR32
  • Like 1
Just a small update, did a little bit of tidying up to the car.
First thing on the list was removing the rear wiper as it didnt work at all (there's still a few little wiring gremlins with the car)
Before:
IMG_5515.thumb.jpg.ece5c84138a13aebf59f59054dbbe155.jpgAfter: (used a bung from the boot floor to fill the hole)
Next up was installing some LED interior lights, found this pretty cool SMD PCB light which is actually super bright. makes the interior feel a bit more modern at night!
Before:-
After:
IMG_5612.thumb.jpg.522c7f2531e727b99fc59c806e700793.jpgIMG_5609.thumb.jpg.7e11dcc09117bbe6d8b7f2bdb3ebc0e7.jpg
Then installed a set of aero wipers on the front, got rid of the horrible metal ones:-
Next mod on the list is installing this when it gets delivered on Tuesday/Wednesday :)
IMG_5641.thumb.jpg.54744ba8703535973b346cd17214d159.jpgIMG_5640.thumb.jpg.7d19445811964532b001a1339ebda0df.jpg
I've also ordered some c-spanners from the UK, hopefully they will be here this week too. then i can raise the car a little bit, possibly get some wider rear tyres if they'll fit - on 235/45/17's at the moment, hoping a 245 may squeeze in once i raise the backend a bit. then i'll get a wheel alignment done.
4 minutes ago, GTSBoy said:
It's kinda not surprising the rear wiper wasn't working. It was installed on the wrong side of the car!
Haha really? I prefer it without regardless, water just runs off the window anyway!
Carbon dmax roof spoiler arrived on Tuesday, went straight to burnings and got some sikafkex 258 - the automotive windscreen stuff. Cleaned the window and the spoiler with isopropyl alcohol and applied a decent amount of sikafkex to the spoiler.
then chucked a ratchet strap over it and placed a bit of weight on top for extra pressure...
Left it to set for 12 hours overnight and it’s safe to say she’s on there for good now! I only have garage photos for now but I’m happy with the look
D43DBB72-F7D1-467C-93BD-4E9F2AA8D283.thumb.jpeg.eeb46781082c7321ee16d8f7bd8a9c23.jpeg9A271BEE-BBFF-41CD-87C8-23754F4A21EB.thumb.jpeg.c0530295b77c0f1a70ad4daed067498f.jpeg73C21AFD-A9CF-42D4-AF5A-3B1D018C2F34.thumb.jpeg.dfca3126c5e21f9dd3480274cf589880.jpeg09F23E84-132B-42A5-B1A7-A8D40D5306C8.thumb.jpeg.2a51c7d6eebdcd0411b42c8a7eb5052e.jpeg
Also had a GTR seat laying around in the garage for a couple of years, thought I’d chuck it in to see how it feels (it’s not in the best condition though). Much happier with the driving position as I’m now sat a bit lower. Now I just need to hunt down a passenger seat and rear bench!C0BC6D7F-74A1-4339-AE33-861E09BA044B.thumb.jpeg.3412ff457ecb574b25a72dff1ee5f5a4.jpeg
  • Like 1
My c spanner’s finally arrived on Friday which meant I could raise the car up 15mm all around, however more importantly my carbon jun style front splitter arrived! Again, I’ve only got garage pics for now but it makes the front look heaps better and gets rid of the paint damage on the oem splitter!
49D19C95-87DE-4F36-9907-2A1AE91907EE.thumb.jpeg.2dc4a685bb397dde69094a3837e9126e.jpeg0772E6A9-D8CD-4A5F-8B92-F7F7D706CEB1.thumb.jpeg.07185cd105bb87cb5148826bf6ebec8f.jpegEB70C29A-2BD3-42B1-88DF-0869C201204E.thumb.jpeg.af385808157d1451895ecce9de79827a.jpeg
ive also ordered some replacement ancillary belts as they are starting to squeak on startup, hopefully they arrive this week.
  • Like 1
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
