1 hour ago, Kinkstaah said:
That is a great way to empty a catch can. A really good way. Now I want a tap on mine as I too have a fitting on the bottom... lol
I actually thought back to my old 25/30 last night when I was thinking about it, my old RB had a -10 or -12 fitting on the bottom of the can, it was VTA and the line went back to the sump because.......if it didn't have a return to the sump, the sump would not have had any oil....
That thing had drilled returns in the head, and a head to sump "drain/vent" line, and oil restrictors, and a regulator on the Tomei oil pump, and a baffled high volume sump, basically every mod in the "oil control thread" apart from the drain back, first outing filled the 2 ltr can and spewed oil out the vent, onto the front right tyre which made me have an interesting excursion into the infield at Wakefield park.
Once the fire hose size return line was added all was well.
Luckly the engine held about 8 litres of oil and I didn't lose oil pressure.
LOL, #RBLIFE
Consider a transmission cooler (and fan, when idling.. especially as a daily!) and/or transmission cooler gauge. I was surprised as to how warm it all got when idling away.
Yeah,trans cooler is going in as well.
Bike just got picked up to get some new tyres and new steering head bearings installed.
The OEM head bearings developed a small knock when grabbing a hand full of front brake, I could have just pulled apart and put back together again and hoped for the best, but, for the small cost of new bearings it was a no brainer.
Plus as the bike was getting new tyres, I pulled the lazy card and got the shop to do it.
And with the car going in tomorrow, my bike and car should be ready for some cruising around over my leave period, I start leave this Friday, and don't go back till 18 Jan 21.
So, my alternator made a awesome smoke show this arvo.
I've got a new one from repco, but, I'm still at work and don't finish till 2200, I need to get this swapped tonight so I can drop the car of tomorrow for the converter.
Hopefully it is a 15 minute job, I hope so anyway because I'm buggered and want to fall asleep now.....f**king last minute.com shit.....
As for my 15 minute job of swapping out my alternator, yeah nah.....I'm pulling the pin for tonight, what a PITA
It seems that my plans for my car tomorrow has changed
Farkkkkk
What a cluster fark
I did by the book, but, because auto there was just not enough room to get it up past the oem trans cooler hard lines, so, the PS pump needed to come out, which was easy and how I should have attacked it from the start.
Now to clean up and put it back together, hopefully it still works......🤪
Private road testing....gave it a little pedal to see how it hooked with the 245/45 17 RE003 and with the aid of 75 litres of fuel in the tank
From a dead stop, in D, trac off, "not" in sports mode (because I forgot to hit the button) it just "spun" up through the gears, definitely needs more positive camber, I'm missing a big chunk of traction.
I have adjustable camber bushings all ready to go, which are a PITA to install, not sure if it will give me what I want though, which is 0° camber, currently I think I'm at -1.0° IIRC.
Meh, fingers crossed
I need to get this sorted before I kill a set of drag radials
In other news it shifts real nice and doesn't change direction much during the shifts
So far so good
  • Like 3
  • Haha 1
There is no hooking with any road tyre.
This is what drag radials are for. Don't stress.
ANY road tyre will spin up with a launch of anything over ... 1800rpm...
  • Like 1
That photo was where it was peeling out of second into third
The pic was more of a reference of how much "face" of the tyre was making contact with the road, as it is, with the current camber, I'm missing a heap of tyre on the outside edges, yes it's a street tyre but it is still sacrificing grip
I wore out the inside edge out of a set of M/T ET steet drag radials on my old skyline from running to much camber, when I zero'd the rear camber the skyline hooked up much better, wore flat, and improved my 60' time by a fair whack, that did go from around -2.0° to 0° though
A rough guestimation is if I can zero the camber I can get maybe 30mm more contact patch per tyre, that has got to help my 60'
Plus the cruise ship doesn't really need any camber at the back, the big fat Bessie isn't ever going to be a car to take fast corners, more a big fat comfortable cruise ship that eats highway miles and lays maaaaad skids
For what I want the car to do, my plan is to just give it a good set up for hard launches on drag radials but still have it compliant and safe for street tyres
In saying this I'm not even sure if my adjustable camber bushings are going to give me any more adjustment than the "camber correction" bushings that are in it now, fingers crossed
AND........GO
  • 3 weeks later...
Compulsive shopper........I said I would never wrap exhaust headers, ever again, but did  then swore I would never again, and then did, the absolute pain in the arse wrapping headers is may have finally sunk in.
I've never used this Thermo-Tec blanket stuff personally but I've seen it used and it seems to work a treat, and holds up well
Not as groovy looking as wrap, but, wrap is the devil to install, this is easy to install, it and should knock out enough under bonnet temps to be worth the $135 it cost
I have struggled with heat in mine, both cabin and in engine bay (like with 0.0% airflow...)
I am quite keen to know how this works, I could actually see myself buying something like this too. I just spent $2500 on sound deadening/heat shielding inside the car and ye I need more.
Does look a bit dinky but everyone looks a bit suprised that I didn't coat/wrap my headers for pretty much the same reason you didn't want to do yours lol.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
