20 minutes ago, Dose Pipe Sutututu said:
AIM MXS dash?
Also can do logging
My curiosity to coin ratio only extends so far
$1500 to see my trans temp and AIT, yeah nah
Plus that AIM dash would look so out of place in the old bogan cruise ship
  • Haha 1
I have a head unit and can thus run any ODB2 app I want. I have the entire torque pro app running in the double din with all the gauges I need.
Note: Don't need any, as I have enough mechanical gauges. But I can put extra stuff there!! And stupid shit like 0-100 runs, or my track day telemetry.
Also Trackaddict is great. And allows overlay for all the circuit things, and does not interfere with god knows what. Go one step further and just tune your f**kin car and buy a MPVI2 lol.
The tech has progressed past whatever that thing is now, and if you want to say have gauges for everything, that is what ODB2 and some kind of display/screen is FOR.
😭 I just want to know my trans temp and IAT 😭
As for tuning, I can barely log on to the interwebs, let alone play with that black magic tuning thing
I can see it now.
"I am going to try tuning my car"........NEK MINNIT.......
  • Haha 2
I can see it now.
Trans temp and cooler are actually pretty important. I remember my hi-stall adventures, its well worth knowing so you can freak out as it climbs in traffic like I did before I installed a fan for it!
  • Like 1
Bugger
The trans doesn't in fact have a trans temp sensor, no trans temp for me thru the OBD2....spoke to Craigs about this and they believe my temps would be fine anyway as the trans has a big pan and a big air to oil cooler, I asked about if cold fluid temps would cause an issue and they said as long as the engine is at temp the trans will be fine.
Meh, the scanner showed no codes though, which was nice
I'm still happy with what it actually can do
Currently it got volts, coolant temp, IAT and boost
I wish I had this when 1. My alternator died, or 2. When my battery died 6 months later..
IAT goes from about 50°c cruising to 80°c during a long hard pull down the local strip at work, hot yes, but hot IAT is a thing with a PD supercharger, you cannot really tell the difference in performance and the ECU black magic deals with it anyway, #notaracecar, soooooo, if my IAT vary from this I may have a coolant flow issue to the W2A intercooler
This tells me that a PD supercharger is great for the street and strip, where a 5 to 10 second hit is all that is needed, but it would be rubbish for the track where you are constantly on the loud pedal, I would assume heat soak would be rampant after 1/2 lap at your local motorsport park, and possibly the ssme for towing...maybe.....
Coolant temps are a fairly fixed 93° c once up to temp
And boost is boost, unlike a turbo which can overboost, the PD blower either blows, or it doesn't, and of it ain't blowing it's because it's dropped a belt
Put a real temp sensor in the line that runs from your trans cooler - That's what I did.
80C while your foot is down? That is ridiculous and has obliterated any desire to ever get on boost.
50C is already massively heat soaked. 80C after a few seconds makes me wonder if your intercooler even exists.
Dang.
  • Like 1
Dang.
But strangely those temps seem to be a thing when it comes to PD blowers, I initially freaked out but the tuner said it is typical, then rang Harrop who said it's typical, then Googled it....google said it's typical and/or that the sensor might heat soak because of it's location, meh, the car is perfect for what I want so
And I knew going in that a PD isn't as efficient as turbos IRT IAT, but I'm happy to compromise a bit, the car goes like a cut snake from idle
Craigs suggested if I really want trans temp to get a bung tapped into the pan for the most accurate temp, I might get this done next trans service
I will chase up some logs from a mates car for reference, it is very similar. I recall it will heat soak high but then giving a squirt will go lower due to airflow .
Lsa engines go up like crazy when giving it a blast. Easily add at least 20 degrees over a quarter mile pass. Those intercollegiate in the blower are laughably small.
Don't look at interchillers. Don't think  about having a system that gives you air inlet temps below zero.
What's wrong with interchillers?
On 09/07/2021 at 11:07 AM, Ben C34 said:
Nothing. It's just something else you will look at and buy but don't really need!
Nothing to see here........
Quietly googles interchillers........again...........yeah, nah, the car is boss for what I use it for and it seriously doesn't need any more power
For the occasional street pull I cannot see there being any real reason
As for unnecessary modifications, well, there is always an electric power steering pump from an Astra, and/or electric water pump, both are not necessary, but for some strange reason I keep googling them........
It's like/is a disease......LOL
  • Like 1
As I was bored at work, and possibly somewhere on the spectrum
I had some of the stuff I used to cover the headers left over.
It's pretty toasty inside the engine bay, hopefully this "may" help with the radiant heat on the cooland lines and reservoir
And running my WTA lines inline with my 90° coolant lines wouldn't have been helping either
Will it be noticable? I'll see gow it goes next outing. Either way it got me away from actually doing real work
EKO TFIF
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
