On 12/24/2021 at 2:41 PM, mlr said:
#Kinkstaah I'll look into the car pulling timing from high IAT, when staging the car it was around 70°c IAT, I'm sure it was heatgun spec at half track
If the car is pulling timing at 80°c then that would explain the low mph
I might see if I can get the thermo that activates when the aircon is on, to be on even if the aircon isn't on, maybe even both thermos to activate off a switch...... or something...... meh, something that the tuner might be able to "black magic" on
This is the stock IAT timing table for a LS1 Commodore.
Remember, you may also actually have heat soak, but the stock sensor on any kind of aftermarket intake just gets heatsoaked to an insane degree without an airbox or some kind of shielding. I relocated my IAT to inside my pod filter but I'm yet to test it lol. Many people in the USA relocate them to outside the engine bay entirely, as it's more accurate to the air that is going into the engine, given it doesn't physically have time to heat up to the degree that the sensor reports.
THIS DOES NOT APPLY TO FORCED INDUCTION THOUGH.
So definitely check it out/look into it lol.
  • Confused 1
On 12/24/2021 at 7:36 AM, mlr said:
Meh, I was smoked by a fairly stock Track Hawk that did a 11.5 and 125 MPH
It was the cars first real run so I'm not to concerned, it ran clean, drove home, and is GTG again
In saying that, if I did buy a SUV, the Track Hawk would be on the short list, they are weapons straight out of the box
400kw at the wheels with Ac off will do that
On 12/24/2021 at 9:41 AM, GTSBoy said:
I'm not convinced that going fast in a tall heavy heap of shit** is a good idea.
** The standard metric for describing anything made by Jeep.
How fun is it riding in cars that shouldn't do what they.
Do you have room to add a decent reservoir that could hold water/coolant with ability to add ice? Or just get yourself a MPVI2 and start doing some tuning at the track. Be interesting to see how much timing is being pulled with IATs
My IAT probe lives "under" the blower
So heatsoak is something that is troublesome to work with
MPVI2??? I'll look into it, but I wouldn't trust myself doing "black magic"
The above chart is how much timing is being pulled, load vs IAT temp and you can see that at your suggested 70C of temp it is pulling 6 degrees of timing at 0 psi.
Obviously your car has boost so that table will look different but if anything on boost I'd wager its more aggressive or what have you, depending on what the tuner has dialled into it.
  • Thanks 1
I use and recommend "old mate towing" everytime I get a transmission full of neutrals
LOL
At least it blew near work, 3 hrs ago we were in Canberra and Goulburn
  • Like 1
  • Sad 2
On 30/12/2021 at 8:18 PM, r32-25t said:
Time for a turbo 400
The cost of acquiring and then building a T400, then the required fab work, for a 3 speed, with no overdrive, unless you sell a kidney, is up to around $15k (I priced up a build for drive in drive out before after I broke it last time)
If it ain't the standard pump rotor that broke, which I can replace with a billet one cheaply, then options will need to be sussed out, like....
Option 1. If trans is lunched: Replace auto with a T56 trans, it may be the preferred option as it is alot cheaper compared to a fitting a T400, and it will easily hold the power the car is making
Option 2. Get Craigs to fit a built T400 (lots of dollars and hard to justify for a daily hack)
Option 3. Replace with another built 4l60e and pull the blower and just go back to NA
Currently Option 1 is looking good
  • Like 1
T56 Magnum is the best gearbox that exists.
I'd say come drive mine to prove it, but we're talking about a box that is warrantied to 700nm, which is 933hp at 7000rpm.
It shifts better than anything else, to boot.
T'was the pump rotor, again
They believe there wasn't enough setback to allow for heat expansion, so they machined the drive hub on the converter to get the correct setback clearance
The cast pumps are apparently fine, but, correct setback is critical, if, due to heat expansion, the drive hub applies pressure to the face of the pump gear, eventually it will break it
So, basically a free fix, if you don't count the $300 on flat beds and the small amount of panic, I was having flashbacks to owning a modified Skyline
Time for a interchiller
On 14/01/2022 at 11:39 PM, Dose Pipe Sutututu said:
ZF or DCT conversion
DCT????? Because they never break and are cheap to fix?????
Nah to either, if I need something the choice with be between a built T400 with tall gears (most likely) or T56 magnum
4L80 is an another option keep that overdrive option
https://www.enginemaster.com.au/hughes-street-strip-h-d-4l80e-transmission-1991-95
Driving a manual in Sydney traffic would get old very quickly.
  • Like 1
The setback was not the only issue
During road tuning the trans they found that it would hit the limiter in 1st and 2nd because the computer wasn't fast enough to shift at full throttle
No amount of tickling the pressures or shift points helped
The PD blower is just making to much torque down low and the 3.91 rear is killing it
Tall gears will help with this, so now I'm trying to workout what gears
My bolt in options are: 2.87-3.07-3.46-3.73
I'm looking at the 3.07
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
