Took out the Cruise Ship for a, um...., cruise
Started early, 0645, Heathcote Road, Princess Hwy, Gong, and then back along the coast and through Nasho, then down to Cronulla beach, ended up coming home via the M5
Fun little drive, apart from one group of push bikes in the Nasho, doing 30kmph in some of the uphill twisties is was "smoooooth sailing"
It is all tucked up into bed now, so....stop......Yaris time
Mark, you must remember, cruise ships aren't built like jet boats... It's probably better you took it through there at 30kmh :P
PS, please keep chasing more power, and taking it to the drags. I want to see you make it able to do this....
https://www.facebook.com/reel/1050511186105137?mibextid=rS40aB7S9Ucbxw6v
if it can't lift the wheels at half track, it needs more power... :P
Nah, it is perfect for what it is now
More power will end up just being another car that breaks all the time and spends it's days, broken, waiting on parts, or in the workshop
I'm happy to just cruise around in it with the family
I'm an old bogan at heart, so cruising around Australia in a blown V8 Commodore gives me the joys
Waiting for it to get fixed because I am trying to get a PB, not so much, hell, that there reminds me of the Skyline, fix it, break it, spend more money to fix it and make it faster, break it, spend more money to fix it and make it faster, break it, spend more money to fix it and make it faster, break it, totally drop my show bags and end up hating the car to the point of selling it, nope, not again
I did come close to going full retard with it though, solid rear, T400, build engine, more boosters, but after having a good hard think, I gave myself a uppercut, it would just end up like the Skyline, a sometimes car that had the tendency to break
I'll let you take the reigns with your build
  • Like 2
Lost a hub cap on the Yaris, somewhere.....
I've found that people want way to much for some used OEM alloys, even a set was mildly guttered and had old worn tyres was $500, fark that
So, Facebook Marketplace "rebuild"
The Yaris is basically a VL BT1 now
20231020_153027.thumb.jpg.54ddc25daff6f8c6665b958587bf428d.jpg20231020_153018.thumb.jpg.93ae284174113e23f89ee07273064ed9.jpg
LOL
Yes, it does need new tyres, that's a job for next week
Also, because "why not", some fresh trans fluid and filter for the "big block" Yaris, I'm just dropping the pan though as I couldn't be arsed flushing it properly
Time for the second coat of race car silver
And because I'm a consumer
Some "hektic" black steel wheel nuts (+10hp)
Screenshot_20231020_202210_SamsungInternet.thumb.jpg.0cfb7f17e102414da9a30479d4050778.jpg
If there "not-shit" I might get some for the Bogan mobile
For $24 bucks delivered next week they are worth the risk
  • Like 1
The Yaris's transmission is basically rebuilt, well.... new fluid and filter anyways, and slightly overfilled, so perfect.
Also order the new tyres for it today, the old ones were 7 years old and toast, so instead of just getting some fresh random cheapo's I got "cheapish"  195/60 15 RE003's on a buy 3 get the 4th free deal, get them fitted tomorrow, so basically race slicks to keep the 80 kwat....engine, in check
And because I'm a idiot consumer, I got a 22mm Whiteline rear sway bar, "apparently" it helps alot with the thing wallowing around in corners and roundabouts going to the shops to get groceries
I even washed it today, and by wash I mean hit it with the gernie foamer with some wash and wax in it, then pressure washed it, then wiped it over with a old T-shirt, perfect
  • Like 1
:38_worried: I believe my cheapo ebay alternator is kaput, fluctuating around 12.2v at the battery when running, and on the scanner it fluctuates between 11.4 and 13v
I'm going to invest in a quality one this time, there isn't alot of difference in the price, and I should of went quality first up, instead of being a bum and trying to save $50
Also, because I'm a idiot consumer, I'm pulling the pin to get the Harrop Gilmer rear drive for the blower, why you may ask, #moreblowerwhinenoises
I'm going to stay the same 1:1 ratio though as the car makes enough power as it is for the street
There is a 1.14:1 ratio available to up the boost, but that would just make my transmission and drivetrain hate life even more than now
I'm just after proper voltage, and more whining noises for the LOLS
  • Like 1
Because I'm a lazy SOB, I got Autotech to pick up a genuine Mitsubishi 140amp alt, and....... the last rear gilmer drive that Harrop had in stock, so no waiting for them to spin up some new stock
Fingers crossed it arrives this week, and it gets fitted up before the SAU NSW Kebab cruise I want to do on 18 Nov. (I'm a sucker for a good Kebab)
I'm also hoping the old alternator doesn't drop it's showbags on the 45 minute drive to the workshop, it is staying on the maintenance charger till I take it to Autotech
Otherwise the NRMA will get another phone call for a tow, I tell you what, I'm getting my monies worth out of my "ultimate car package" with this thing :8_laughing:
  • Like 2
45min you should be OK if you start with a full battery and it is not raining or night (headlights).....I managed to drive the stagea about 55min to the middle of nowhere when I discovered alternator was dead.
Plus, that was that time we were leading the wakefield 500 by almost a lap at hour 5....when the battery finally gave up since the alternator had been dead for ages. "we was robbed!!"
  • Like 1
The difference a OK set of tyres and the rear swaybar has made is astounding
Whilst it is as slow as 10 slow things acceleration wise, it now handles corners exceptionally well, no more wallowing around corners, and super settled in change of direction
It is now the perfect, cheap to run, little daily that shoots through corners on the way to and from work like a champion
It's no i20N, but that is a story for another time
  • Like 2
On 11/8/2023 at 4:11 PM, The Bogan said:
Sounds good
29 minutes ago, The Bogan said:
Fits the theme of the car, it needs them
  • Like 1
15 minutes ago, robbo_rb180 said:
Sounds good
I will need to black out the HSV stitching though, apart from that I really like them, and my 22 year old seats are starting to show a bit of bolster wear
Cost is significant though at a smidge over $4k
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
