1 hour ago, Kinkstaah said:
Why didn't you buy the one I originally linked in QLD which was about 18k and in massively better condition with about 30k of tastefulmods holyshitmygodjesuschristman.
I've driven that one and it's a great deal and drives nice. The owner definitely treats it right on track. You would have gotten it for what you paid for this one too.
Keen to see what you do to this one.
  • Like 2
The one I got has 50k km less on it, and is in good nick, plus was relatively local, I wasn't going to fly into QLD to look at a old MX5
As for the mods, meh, I just want a comfy fun little car for the street
In other news, we took it to Goulburn today to lunch with the daughter, good times
Mrs did insist on me putting the roof up about half way there as she said it was to cold, I did tell her to rug up before we left, but, nope, fashionable attire won, bloody convertible rookie
  • Like 1
2 hours ago, Duncan said:
This thread always delivers, thanks again mate
Talking about deliveries
I have one on the way from MX5 Mania already, only for a little added noise really
Plus I'm waiting on Super Cheap for every oil, fluid, filter that goes in it, and some new plugs for it as well, because why not
After that is all finished it's off to MX5 Mania for the ECUTEK, mainly because I want the rev match for when I'm racing to work or the local Coles shopping centre 🤪
Axle back, new thermostat and coolant bottle arrived from MX5 Mania, I'm still waiting for Super Cheap to get back to me with my order, once I get everything in my hands I'll take some leave and "play", starting with serving and fitting parts, then detail
I honestly think this is the most fun part about getting a new old car
1 minute ago, MBS206 said:
In roughly 6 to 9 months time, what mods will you have done, and how much can I buy the car for? :P
I thought you might have asked about the Honda, but as the boy just wrote off his Patrol, and was trying to find a cheap daily to get by with, I decided to give the Honda to him
Ha ha ha, I read that he had it based on brownie points so knew it wasn't going to be sold :P
I also am only shit stirring on buying, while they'd all be great cars, I don't need more, I actually sold one a few weeks ago. And immediately bought more tools... :P
  • Like 1
Talking about tools, my trombone cleaner arrived, talk about weird speciality tools....
Bored at work, so...
Out with the old
In with the new
Sounds good, and most importantly, no drone
Thinking about being bored at work again tomorrow, or maybe give myself a EKO so I can do the new thermostat and coolant reservoir
4 hours ago, Dose Pipe Sutututu said:
Mark needs to get bored at work and order things on here...
Whilst putting a V8 in a MX5 would be fun, it would negate the whole cheap to run fun daily that the MX5 will be used for
If I wanted a faster little convertible I would have got a engine check light, I mean a BMW Z4 M, but going off the issues that the guy at work who recently got one is having, it is lucky I didn't
Meh, horses for courses, the Bogan Cruise Ship is my go to for some horse torques
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
