7 hours ago, R324u said:
I was able to make some progress on it  last night by doing this just saw your post., I had to set the dash to default, what car are you using this on an r32?  I’m using pin 21/ 30 for the ground but those wire colors  you mentioned don’t match up to what I have so I’m guessing you have a diff chassis
Yes those wire colors are specific to the R33
  • Like 1
Hey guys im trying to get my fuel level to work also on my haltech ic7 dash. I have an r34 4 door and im using pin 6 as signal and pin 55 as ground but im not getting any voltage value with a multimeter. I currently have 1/4 tank  and testing them two wires at the tank plug or at the dash i get the same reading (shows 0.01v this doesnt seem right). Can any one shed any light on this. Ive setup the dash on avi 1 and calibrated to 0 to 90 ohms, factory is ment to be 6 full 80 empty attached is a pinout for an r34 4 door for any one else chasing a diagram pin out. Am i missing a step or not testing the right wires??? Thanks guys
UPDATE
So i should have mentioned im fully replacing my dash with a haltech ic7 display so my factory dash was not plugged in
Once i plug the original dash in im getting voltage output there.
Fuel light came on and i was getting a fluctuating voltage of 1.0v to 0.9 volts fuel light just came one.
Filled up voltage now reads fluctuating 0.15 to 0.10 volt liters filled to this point was 51 liters so im lead to belive these sedans have a 60L tank so i know zero on my haltech ill have approx 10L left.
My question is if i unplug the dash will i still get a reading now or am i missing a wire to join in the harness iim lead to belive no
Edited by 26GTT
Far as the fuel reading it looks like you should be using pin 7 and 55
49 minutes ago, 26GTT said:
Thanks for the reply  mate, sorry thats a typo i am using pin 7.  So last night i tinkered with it a little more, with the factory r34 dash plugged in you get a voltage value but once you unplug the dash you loose these voltage values.
Are the wire colors from the fuel tank match the wires colors of pin 7/55?
ANOTHER UPDATE
So i now have it working and reading off the haltech dash 😄😄😄😄😄
But i still have a slight problem, im actually replacing my factory dash with the haltech unit. The 2 sender wires only have voltage when the factory dash is plugged in.
Both factory dash and haltech work and read correct but as soon as the factory dash is unplugged you loose the fuel level on the haltech??? Any ideas guys.
4 hours ago, 26GTT said:
the signal wire is yes (purple pin 7) but the ground wire is (black pin 55) at the tank and black white at the cluster
Only solution i have is find where the black wire ends in the cluster area and splice off it /  splice and run a wire from the tank to the cluster  / buy the fuel sender conditioner
  • 3 weeks later...
On a seperate note. Has anyone got flex fuel percentage to show correctly on the dash?
In the haltech I can see "flex fuel" and it shows the right ethanol percentage when I check it with a laptop. So my flex tune seems to be working (currently 48%).
However on the dash I choose "fuel composition" and it just displays 85%, never changes, seems super random.....
On 13/11/2020 at 12:35 PM, SLVRBAKSLPZ said:
I wired mine up about an hr ago and it worked..
The the red/gray wire for signal (i used pin 18
The teal wire is the ground for pin 30
Make sure to select the correct channel for the AVI you used. And use 90-0 ohm
The you select the spot on your dash for the fuel level choose the AVI, not fuel level.
You still are required to adjust the voltage.
So just confirming grey/red c29 wire to avi pin of my choice for signal and the light green/ silver wire c32 to earth input 30. Is this all you need to wire in for the fuel gauge to register?
Yes that correct. Sorry for the late reply
What voltage are you guy getting on your fuel sender? When i checked mine the Ohms read proper. When i plugged up to check the voltage i was getting very super low numbers (Full 0.02 // half 0.13 // Empty 0.42.
1 hour ago, 26GTT said:
So for my r34 sedan
Full is 0.2v
3/4 0.6v
1/2 1.0v
Fuel light 1.6v
This is using a haltech fuel conditioner in line to my ic7 as i found it helped the gauge be less erratic
That seems to align to what I have :)
9 hours ago, 26GTT said:
So for my r34 sedan
Full is 0.2v
3/4 0.6v
1/2 1.0v
Fuel light 1.6v
did you use the pull up at all? and whats your filter level?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
