a couple of Doberman's / Rottweiler's that havent been fed in a while....
In all seriousness though, i think the best security are them posts that you bolt to the floor in between the car and the garage door.
And possibly an elaborate kill switch of some sort thats truly hidden away.
Edited by DaymoR32
  • Haha 1
3 hours ago, Mathew1988 said:
Hello all
Just wondering what people recommend / using for a security alarm system for a BNR34 GTR Nur please?
Kind regards,
Mathew
If your in Sydney I've used a guy, recommend from here, that could sort the car part out.
I cannot remember his name but if you want I can PM his number
That is for alarms and GPS and stuff.
The best security is to keep your location on the downlow and use the alarm gps stuff as the last layer of security.
The first layer is not letting people know where the car is
The second is area/access (home) security
The third is cover (garage and car cover)
The fourth is hard obstacles (bollards)
The fifth is an car alarm and GPS
That keeps it nice and safe (ish) at home even when your not
  • Like 1
On 7/28/2020 at 9:47 PM, Mathew1988 said:
Hello all
Kind regards,
Mathew
if its locked up, autowatch did a decent unit - 457 RLI and the GPS unit to go with it. whoever does it needs to BURY both units. if the have the lower dash off only then it means the average joy rider will have it disabled in 30 sec. when I did these (search the forum for my name) it was a 2 day affair usually and I charged accordingly. dash completely out , unit buried and fully integrated into the harness and OE relays used for the disable points. even those were hidden well. I retired (not by choice) in early 2017 and do GPS telematics in the USA now for Verizon/Vodafone.
^^ correct.
where I live (I am in Texas)  there are only a few people that know where my R31 and F31 are kept. Only two people that know how the start the R31. myself and the mechanic that I use to work on it. (I stay too busy now to maintain the thing.) both cars have full time remote monitored GPS by a monitoring company.
8 hours ago, Chris Rogers said:
^^ correct.
Want to install an autowatch 573 for me when the time comes?
  • 3 weeks later...
I no longer do car security :) . may focus of work now is with Verizon Telematics in the USA where I now live.
573 is a dongle and hasn't been available in australia for a number of years. last one I sold was in 2014.
On 8/20/2020 at 12:29 PM, joshuaho96 said:
I'm in the US, I think you can still buy one in Canada.
that changes things. if you are TX - then yes I will do it. far better to do a 457 though. I can set that up so only a tow truck will move that car. actually you could do a 674 as well.
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
