So, I got a brand new Haltech Platinum Pro, Haltech wide band, and Haltech boost solenoid at a steal. I know I'll need them next year when I start really building the car, but are there any benefits on an otherwise stock motor, stock turbo, stock fuel system car that would make it worth installing now?
https://www.sau.com.au/forums/topic/480955-haltech-platinum-pro-stock-r33/
yes. Few reasons below
  1. you will be more familiar with the software and logging when it doesnt matter so much so no real pressure
  2. you can have safeties setup so if something happens it saves the engine (overheat, low oil pressure, low fuel pressure, etc)
  3. set the tune up to shoot flames to make up for car being stock, thats heaps of points right there especially in America!
  • Like 1
  • Haha 2
  1. set the tune up to shoot flames to make up for car being stock, thats heaps of points right there especially in America!
Lol'd way too musch at this.
Definitely put it in, as above with becoming familiar with the software but also niceties such as better fuel economy, cold/warm starts, closed loop boost control even diagnosing issues with igintion and sensors is so much easier as can log everything.
  • Like 1
If you put in a wideband sensor you can run the car slightly leaner on boost, pretty sure the stock map is like 10.5:1 AFR or something hilarious like that. You can lean it out a bit and avoid running into excessive rich/retard if you turn up the boost. Generally cleaning up fuel and timing like that will improve fuel economy and response.
3 hours ago, Blakeo said:
Throw the Haltech right in the bin and get a Link ecu. They are way better and more reliable.
Based on what evidence? I've never had an issues with the Haltechs I've tuned.
It's 2020 not 1999 when Haltechs were in fact junk and unreliable.
I had a Haltech Platinum in my R33 that had 101 problems, Haltech were helpful but getting a replacement ecu after changing basically everything mechanical wise with their advice was nearly impossible (kept blaming everything but the ecu). Ended up opting for a refund, bought a link g4+ and no issues with the same setup.
Maybe its your luck, to be honest I've never had a single problem with any Haltech (I've setup/tuned about a dozen).
Not saying Link isn't a fantastic ECU, just I've seen too many people quick to blame something too many times on this forum.
Also replacing a Haltech Platinum Pro with a G4+ is not an apples for apples comparison. Did you replace an Elite 2500 with one?
Generally speaking most standalone ECU's only really cause issues when wired in wrong.
There are always benefits to aftermarket management if you know what you are doing, or are curious to learn and get it right. It can be very satisfying!
this!
Especially when you get people use the ECU IGN power to power their wide bands, and when you see people using chassis GND for sensors.
Funny enough, I had to correct wiring on IS200 with a 1JZ swap wired by a "motorsport wiring professional". He had the wideband sensor GND output to the chassis then told me to use a voltage offset in the ECU. Then when setting up the tune, we found issues with the coolant temperature. Turns out the "motorsport wiring professional" had 1x sensor connected to the Elite CTS input and also the stock Lexus ECU input.
Now is it really the ECU's fault here?
  • Like 3
Haltech Platinum Pro, was a plug-in deal. My wideband was wired in using a separate relay, and the signal ground from the ecu (as recommended).
The Link was a lot more cost effective compared to the Elite 2500, and from already having a bad experience I was more comfortable going with the Link and happy I did. It's a very capable and reliable ecu, the help documents are second to none and everything just works as it should.
I'm sure the Haltech is good too, if your lucky enough not to get what I and my tuner believed to be a defective device.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
