Hello,
i am building a 350z drift missile with a florida imported Aristo 2jz GTE VVTI
My partner and I are trying to make it as "budget friendly" as possible while still retaining reliability and decent performance. We have a build list of new parts such as top mount manifold, turbo, gaskets, studs, oil pump, water pump etc etc.
So here is my question.... while the engine is out, we were planning on doing all the rotating assembly bearings and we were wondering If it would make sense that we pull the pistons out, clean it up, then replace all rings, then finally hone the cylinder bores with a honing pad/stone ourselves
I know that you shouldnt trouble the rings and bores if you are making good compression but if the engine is out... wouldnt it be a good idea? Is this too risky? i have seen a few people who have just got a hone and new rings and reused the stock rods and pistons but i would like to know if honing is something you can do your self and still achieve good results.
https://www.sau.com.au/forums/topic/481218-engine-rebuild-question/
EDIT: look i know that you  "CAN" do it your self and there is a few videos on youtube who show them selves at home with a drill and what not but i want to know if what they are doing is wrong and if they are just a set of bone heads. so yeah thats my question... lol ?
Yes, you can. The main issue is the drill speed too fast and it cuts too shallow a cross pattern. Something slow, eg cordless drill on low speed and a fast up/down motion, will work fine. Does't need long to work. Yes you should replace with new rings while out, and from there yes you should re-hone.
  • Like 1
If you pull it to pieces and the cylinder bores don't show much wear and the rings look good why touch that at all unless you are paying to do it right?
Actually, This ^.
Just because you pull it apart doesn't mean you automatically do anything. The only thing you have to do is carefully inspect and measure everything. If the bores are round and especially if there is no nasty lip at the top and especially especially if the hone marks are still visible, then doing anything to the bores is unjustified. You always assess what you have before deciding what you're going to do to it.
And then forget what you decided and mash the go button on that Nitto stroker kit.
  • Haha 1
2 hours ago, Unzipped Composites said:
Humorous reference to the natural tendency to completely blow the budget despite the intentions going into the build.
i was attempting my own humorous reference to accidentally purchasing hks h-beams (and a billet crank, which a workshop “lost”)
hey, each to their own...but, if i'd picked up a 2nd hand unknown engine, I had it apart, and was rebuilding it to ensure it was fresh and ready to last for me, there's no way i'd be sticking with the rings that were in it; i'd replace them along with bearings, water pump, timing belt, anything else that might " look fine". A set of rings is like 200 bucks, a hone does effectively nothing to the bore size, and pulling out and dismantling the engine is one Fkton of work, as anyone that's ever done it knows, so replace them while it's all apart, if budget isn't the utmost concern.
  • Thanks 1
On 25/09/2020 at 6:57 PM, Duncan said:
Are you putting a 2jz in a 350z for a cheap project?
4th time this week, thanks skid factory.
Adam lz has put more Jz engines into cars then the skid Factory
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
