I don't see much talk if any about them on here.
I know they are really popular in the States so they have more people talking on forums there but i was hoping a few crew on SAU have one or are keen to get one.
 Well if you come across this thread and have a V37 post a pic and say hi 😁
  • Like 2
https://www.sau.com.au/forums/topic/482161-who-has-a-infiniti-q60-q50-v37/
On 3/27/2021 at 5:40 AM, The Max said:
They look menacingly stunning but I'm not keen on their overly complex coolant plumbing for the turbos.
Just the unfortunate reality of making a turbo engine with truly modern power delivery. The W2A charge cooler adds a second coolant loop and makes things very messy in the vicinity of the intake manifold. A2A eliminates the extra plumbing and issues with coolant leaking into the engine but now you have a bunch of additional volume after the compressor that has to be pressurized to build boost.
You're right. It is an exercise in compromise. I much prefer the lesser complexity in going air-to-air and the amount of people who've reported on their coolant system spewing forth their contents after a hose failure is well-known.
It's the only reason why I would avoid buying one, despite how pornographic they are to my eye and have me lusting after one!
On 3/29/2021 at 3:26 PM, V35_Paul said:
That is so cool.
How do get to watch that event?
They used to be on TV here in NZ last season.
I'm not sure what engine they ran but I think they used the Merc engine which could of been the 2LTR Turbo.
(Please correct me if I'm wrong.)
  • 1 month later...
it is very much a performance focused hybrid, not economy focused, put the boot in and it will drive with both petrol and electric together, but won't run both together under normal driving.  When the engine is running while accelerating or cruising it has a heavy preference to use the petrol engine to drive the car and charge the battery, once there is enough charge in the battery while cruising at a constant speed it will switch to electric only and shut down the engine until either the battery charge level gets low, or you give it more throttle than it can cope with in electric only.  it shuts down the engine while decelerating and charges the battery via regenerative braking.
Will run on electric when it can while cruising up to about 105-110km/h, above that mine keeps the engine running all the time and only uses the electric motor if you put the boot in to overtake., I have heard the RWD will run on electric to cruise at higher speeds, probably due to less drive-train loss..
Otherwise it drives a lot like a conventional car, it is a normal 7sp auto, just has an electric motor and dry clutch where the torque converter normally is, transition to electric/petrol is very smooth, you often don't even notice if you aren't watching the tacho.
I haven't driven the VR powered Qs, but have heard the performance sits somewhere in between the 300hp sport and 400hp red sport.
Edited by sonicii
  • Like 2
  • 1 year later...
That sounds like the JDM models, they have the infiniti logo on the front, but 'Skyline' across the back, the hybrid wears the 350GT badge too.
That said, I didn't think the JDM models were eligible for grey import??  unless they are AuDM models that people have retrofitted with the skyline badges.
  • Like 1
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
