Car is hard to start when cold. just have to give it some gas. changed cold start valve did not help issue.
Car coughs at idle about every 1-3 seconds. cleaned and inspected IACV all clean and works. still not helping.
Car stalls with clutch pushed in when coming to a stop when cold. only happens 50% of the time.
Checked TPS all good and reset.
Car is stock. Brand new OEM coil packs, new spark plugs, new OEM fuel pump and fuel filter. Confirmed no vacuum leaks.
MAF is clean. Idle does not hunt. wiggling the plug to MAF when car is on doesnt affect idle.
Throttle body is clean and cable tightened correctly.
I checked the forums here and what i said above is what people say will fix the issue. The coughing idle is what really bugs me. everything else i can live with.
Car is perfectly fine in every other regard no issues anywhere else.
No i cant just borrow parts from another skyline.
Is the AAC valve blanked off or blocked off? they seem to fail quite a bit and most people just block them off to stop the high idle.
Consequence to this is pretty much what you're describing.
Another way around all this, convert to DBW and throw the IACV, AAC valves all into the bin ;)
No its not blocked off in any way
This stupid thing, it sits under your top part of your plenum. A karnt to remove/reach
Iacv Rb20
I just finished installing a brand new one of those today. It didnt help the problem. is blowing into it just making sure it starts to close and works?
If the motor is cold, you should be able to blow into it, once it warms up it closes up.
When you unplug the O2 sensor does it idle better?
I forgot to mention that the O2 sensor is also brand new but i will try disconnecting it in the morning. Thanks for the help so far mate.
10 minutes ago, admS15 said:
You forgot samsonas, slipping brah..
fuark.. soz...
Let's try that again
All else fails, CAN O2 wideband, IAT, DBW, DBW pedal, Samsonas,  modern ECU conversion 🤣
  • Like 1
  • Haha 1
Iacv Rb20
Hey @Dose Pipe Sutututu just to be clear that is an IAC valve, or air regulator valve as the manual calls it, not an AAC valve. The air regulator valve gets a constant 12v on it fed from fuel pump relay and the AAC is pulsed on the ground by the ECU to control the solenoid duty.
To test the air regulator valve as per the manual, without power the valve is only fully open at -20 deg. C, half open at 20 and fully closed at 60. If you 12v power them they are supposed to gradually close fully within 7 minutes. Resistance across terminals is 75ohm at 20c ambient.
@BK perhaps I got the terminology wrong, that device isn't the idle control valve though
The idle control valve sits on the plenum itself. The IAC valve pretty much just has a diaphragm that closes as the motor warms up.
Yes it does exactly as I mentioned above. It is actually powered to heat up and close, not just engine temp. IACV is probably not a very correct name for it either, but it is certainly not the AAC valve which has the idle screw and solenoid on it as you would know.
Should really be called the fast idle thermo valve, cold start air valve, or something similar that at least indicates that it's associated with cold start air regulation. My advice as I've been working through my own car is to get Nissan Datascan with a Consult cable and take logs when the car is misbehaving. You have to see what the ECU is seeing to understand why the engine is behaving the way it is. The ECU itself has very weak self-diagnostic capabilities, basically the only codes it throws are for things like open circuit/short circuit. All the sensor plausibility stuff is entirely on you to diagnose. How stable are AFRs when the engine stutters at idle? What does the MAF signal look like? Really meditate on the logs before you throw parts at the car. If you're suddenly losing consult cable connection during those drop-outs I would start suspecting the ECU or whatever is supplying power to the ECU.
I just purchased data scan with cable a few hours ago. Thanks for the help.
Once you get logs of the issue feel free to upload it here, I can try and stare at it and see if anything stands out as well.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
