After years of delays hold ups, lack of motivation... I Got the Engine done and took the old girl where she belongs, back to the track. 95% off all my research was on here trawling the forums for engine build info. Ive got vids on all the rebuild including every failure along the way but it was all worth it because.... well look below i's awesome 380RWHP on 14psi running her in, can't wait to turn her up.
Edited by Tangles01
  • Like 5
https://www.sau.com.au/forums/topic/482471-r32-gtst-time-attackhill-climb-car/
Hey mate, great vid. How do you get 380 RWHP on 14 psi? I am running an RB256DET with same RWHP but at 20 psi.
Can you tell me what you have done to the engine as mine is pretty standard apart from forged internals, balance and bigger injectors with a Nistune board and LM TD06/25G turbo on a standard manifold.
Thanks.
GTX-3076
10.5:1 compression
E85
262 tomie cams
Hand ported head
VCT
Custom 6boost style mani
3.5 inch zauzt
690nm peak torque
And it's fresh obviously. I need to do a comp test now it's run it.
More supporting stuff but those are the power makers.
All the build detail is on the channel
Edited by Tangles01
15 hours ago, Tangles01 said:
GTX-3076
10.5:1 compression
E85
262 tomie cams
Hand ported head
VCT
3.5 inch zauzt
690nm peak torque
OK now I see why thanks. Yes, should be a bullet once 20 psi dialled in.
I'll have to be honest, I winged it on that lol. But head and block were virgin just got a skim for the MLS gasket and sent it. I did hand rotate her, clear is clear.
Edited by Tangles01
  • Haha 3
6 minutes ago, Tangles01 said:
I'll have to be honest, I winged it on that lol. Bit head and block were virgin just got a skim for the MLS gasket and sent it. I did hand rotate her, clear is clear.
That's not true mate, clear by hand vs at 7000rpm are 2 wildly different things!
Yes that's true mate. but still it works. And there was a silly timing issue where if it were close it would have kissed the valves, so I'm pretty confident it's okay. I might have gotten lucky, I might have measured the piston height. It was that long ago when I did it I can't honestly recll, but I remember not doing much about it, and not doing it right if I did anything.
  • Like 1
  • 4 weeks later...
On 13/07/2021 at 1:57 PM, Tangles01 said:
1.53.001
1.53.001
Hillclimb looks great. Much better than what we have here in NSW. Where is it located?
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
