Can't find a thread on this so decided I'll make one to hear opinions. Just want to get some opinions on the different intake manifold options for RB's, particularly if you have actually seen or experienced the ones you're going to mention.
Has anyone used the Otaku Garage ones, NPBoosted etc? Reputable or just look the part?
And yes I'm aware plazmaman is great, just want to see all the options and what's out there, because mostly I see people run either plazmaman or cheap ebay lol but surely there are more?
Also have a number of my own reasons for running an ffp, for anyone who's gonna tell me to stay stock. Aesthetics is certainly one, which is why I'm not actually too fond of plazmaman haha
So leave your opinions and reviews below.
https://www.sau.com.au/forums/topic/482778-intake-manifoldplenum-options/
Otaku/rep/copies notorious for splitting
Any short runner manifold will be a performance hit in the low/mid range, even the plazmaman one.
Used Genuine Greddy and lost all low/mid torque, Quality was good 2007/2008
Currently using Plazmaman Plenum on std runners. Got all my low down torque back and Quality is great 2018
  • Like 1
That's interesting as I haven't heard bad things about otaku intakes yet, but I haven't heard much about them either. And yea def don't want to sacrifice too much low down, I've got an Rb20det after all haha
Does the Nismo plenum make more sense then for people that want to light a lot of money on fire for basically zero benefit? They claim the intake runner length is 73.8mm compared to 48.5mm for the OEM part. Plenum volume is 4.1L vs OEM 3.4L. Supposedly cylinder 5/6 have a different runner geometry as well to try and get it to have more even air/fuel distribution.
On 9/1/2021 at 4:44 AM, joshuaho96 said:
Yeah, this is an RB26. Probably should've mentioned that part.
In that context, the Nismo plenum, if it offers the benefits that they claim, would be a good thing. The larger plenum volume will certainly help on big power cars. The improvements to the runner geometry might help. The length increase would be unnoticeable (except inasmuch as it might contribute to the large volume).
Thanks for the comments so far.
Anyone else have experience with different intakes? Seems to be a case of either buy plazmaman/greddy or some ebay junk (or fancy name ebay junk with their own website) lol
It's for an Rb20det btw
Have a look at IMR in NZ.  He’s a one man show that makes some pretty awesome intakes.  I’ve got one for my car that will be DBW. It’s very well made and looks awesome  I’ll probably powdercoat it as well ven though the raw aluminium looks bloody good.
Mine-
You’d have to hit him up for a price for an RB20 manifold as it will be obviously different to an RB26.
I would keep the stock RB20DET plenum and run Plazmaman swept back piping.
Save that money and put it towards a sex spec modern turbo with a divided housing, twin scroll manifold, twin gates. That RB20 needs all the help it can get And throwing a plenum on is going backwards.
  • Like 1
Not keeping stock, for a few reasons like I said. I do intend to keep the runners as long as I can to not lose so much low down torque. Aside from short runners causing the curve to be higher in the rev range, therefore sacrificing low down, a forward facing is not going backwards.
It's also getting a 6boost manifold and a Garrett turbo lol so those are in the plans
Mine-
Thanks for the input I'll have to look into it, but def need runners to be a lot longer than that lol
Just remeber you don't have VCT and you have a 2.0L motor so the best option here if you want to go FFP is the Plazmaman plenum that utilises the stock runners.
Remember to go a divded rear housing on the turbo and twin scroll manifold. You'll need all the help you can get.
Yeah plazmaman def seems to be the go, I was hoping to see if they had a good competitor for performance that just looked better hahah. But options are just a bit more limited on an Rb20det, without sacrificing what little it has low down lol
These are the key points. Any sacrifice of what the RB20 has to offer before the boost threshold only hurts driveability. You can make an RB20 make lots of power, but when you do you get nothing, nothing, nothing, wheelspin.
I'm not disagreeing lol it's a street car so I want drivability, hence my search for a good intake that doesn't have tiny runners. There's always gonna be *some* sacrifice. But I'm not chasing massive power so it should be still good to drive, for huge power I'd look for an rb25det.
Bad things are literally all you hear about the Otaku Garage intakes.
  • Like 1
    • That's not a transistor --- it's marked ZD1 which makes it a zener diode. As to what the breakdown voltage is, not enough there to divine.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
