Buy two fat muffler and get an exhaust shop to make a custom one up for you.
You can buy a turbo cat back but it will sound as good as a fart cannon, so better off going to a parts store and buying a fart cannon and installing that instead (cheaper).
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955319
Hi,
Thank you for the answers :-)
I send message to nengun about that exhaust and sadly it wont fit(plug an play).
But i can buy the end of the HKS muffler and rest of it i can do with custom :-)
I know it is a long shot but this sound is nice.
Anyone try to guess what this should be? Sounds exactly how i want it. I try to message the guy but he do not reply :-/
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955331
On 8/31/2021 at 4:39 PM, Kapr said:
Hi,
Thank you for the answers 🙂
But i can buy the end of the HKS muffler and rest of it i can do with custom 🙂
Anyone try to guess what this should be? Sounds exactly how i want it. I try to message the guy but he do not reply 😕
Just sounds like an NA RB. Just like an NA RB.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955339
@GoHashiriyathank you i will check them out 🙂
@GTSBoy yeah i know but with custom exhaust...the stock NA RB(with stock exhaust) do not sound like that 😕
I know just from the sound only...but i was curious if any would guess what type of exhaust it is(muffler delete or straight pipe etc)
IMHO it sounds like Silent type 🙂
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955348
Just to back GTSBoy up here, what OP is hearing is a placebo. Mufflers don't REALLY (they do a little, but honestly not much) change the sound of any exhaust, though they do change the volume.
ALL RB's sound similar. Indistinguishable. You'd get more difference out of changing the cams, or manifold, which noone really does. (for purely sound reasons). It comes as a byproduct of turbo/performance which aren't the issue here.
Sometimes there's not a lot of search results because it became kinda self apparent 18 years ago. The differences you're likely hearing between videos etc are far more likely to be mostly caused by the quality of the recording equipment and how that's been setup.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955392
@Kinkstaah I know about the different sounds and quality but this is the only "good" one with same engine as mine.
I do not know what he has in that car but from many videos i saw it should only be the exhaust.
I have the "boring" twin stock and that not sound like that.
Sadly i cant just try different cuz as you know...GTT let alone GTR have different type and far as i know iam the only one in the country with this type of a car(R34 with RB20DE NEO).
Best i can do is to buy HKS but only the rear muffler (for the looks) and rest will be custom made.
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955394
There are literally thousands of different types of mufflers available on the internet. One being branded hks isn’t going to be any better then one branded magnaflow for example
forget buying a branded one. Just go to the local exhaust shop, tell them the size of exhaust and style of muffler you want and that’s the end of the story
listening to different videos will sound different depending on what sort of device you are watching it on,( mobile, tv, sound system etc) the quality of the device used to record said video.
  • Like 1
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955396
For the OP's purpose, yes just get any decent muffler you can afford, doesn't have to be JDM fanboi brands.
In reality the sound can slightly differ between them though.
Quality of packing, How the packing is wound, Type of packing (Fibreglass wool, ceramic wool, stainless wool) can change the sound of a muffler. Hell, even the size and shape of the perforated tubing inside the muffler can change the note. Some are high pitched, some are deep and smooth, and some will blow the ass end out when you 2step limiter at the local cars and coffee.
Personally for a Non turbo, try find one that has a smooth deep tone, which would be your large oval shaped mufflers like Magnaflow, Xforce etc. The fart cannon will sound shit.
Edited by djvoodoo
adding info
  • Like 3
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7955398
  • 3 months later...
On 07/12/2021 at 5:29 AM, Kapr said:
Hi...dont want to start a new topic so i ask "again".
Is anyone know if 25GT(RB25DE NEO) has same exhaust as GT(RB20DE NEO)?
I saw that i can get Kakimoto Hyper Full Mega N1 exhaust but it is only for 25GT. Model number is N31354.
Thanks for the info 🙂
It should bolt up fine, personally for na I think the stock exhaust is the best, it's just more noise & usually not a nice noise & doesn't go any better
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7958500
interestingly (or not) the biggest change in exhaust note that I have found, apart from changing from the stock exhaust obviously, was changing to Supertech valve springs and titanium retainers (on an RB25det-onation). Immediately picked up a sharper more RB26-like sound once they were fitted.
  • Confused 1
https://www.sau.com.au/forums/topic/482780-which-exhaust/#findComment-7958617
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
