R33 Gtst ECU Engine Control Unit RB25DET ECU MT (23710 21U01)
Skyline R33 front grill S1
Nissan skyline R32 Upper lip boot interior boot trim
Nissan Skyline R33 brake Master Cylinder ABS
Skyline R33 S2 A.B.S UNIT
Skyline R33 Quarter Trims S2
Skyline R33 Quarter Trims S1
Skyline R33 Cam angle sensor
Skyline R33 TailShaft
Skyline R33 wiper and indicator stalks S1
Skyline R33 wiper and indicator stalks S2
Skyline R33 washer Bottle
Skyline R33 centre console
Skyline R33 ignitor with bracket RB25DET
Skyline R33 Rear Bar (grey)
Nissan Skyline R33 GTS-T Auto updated shifter from 1997 model
Nissan Skyline R33 Power Steering Rack
Nissan Skyline R33 RH Half Shaft
Nissan Skyline R33 C-Pillar Trims
Nissan Skyline R33 Rear Seat series 1 Complete
Skyline R33 Boot Lid & Fuel Flap Release Handle with Cable
Skyline R33 Alternator
Skyline R33 Power Steering Pump
Skyline R33 Ac Compressor
Skyline R32 Bonnet Release cable
Skyline R33 Bonnet Release cable
Skyline R33 Handbrake Lever
Skyline R33 S1 RH FOGLIGHT
Skyline R33 Power Window Amp Relay
Skyline R32 Manual clutch master cylinder
Skyline R33 Manual clutch master cylinder
Skyline R32 Brake Pedal Assembly M/T
skyline R33 rear taillight left hand side
Skyline R33 Stock Intercooler OEM (side mount)
Skyline R32 Clutch Pedal Assembly M/T
skyline r33 single din dash pocket with a working lid
Skyline R33 2 Door Genuine Seatbelts (complete set)
Skyline R32 Door Glass (Genuine)
RH AND LH Side
Skyline R33 S1 Rear Garnish
Skyline R33 S2 Rear Garnish
skyline R33 Starter Motor RB25DET
Skyline R33 boot interior lining
Skyline R33 Rear Quarter Glass And Seal
Skyline R33 Steering Column
Skyline R33 front Reo Series 1 (UNCUT)
Skyline R33 Rear Reo
Skyline R32 Rear Reo
Skyline R33 Rear Antenna
Skyline R33 Front guard LH
Skyline R33 Front guard RH
skyline R33 coupe glove box
skyline R33 S1 passenger seat
skyline R33 S2 passenger seat
skyline R33 coupe Mirrors LH and RH side in black
skyline R33 coupe window motor with regulator LH
skyline r32 coupe window motor with regulator RH
skyline r32 coupe window motor with regulator LH
Skyline R33 original left hand side weather shield
Skyline R33 climate control
Skyline R33 GTST stock exhaust manifold
Skyline R33 front fuse box cover
Skyline R33 door Scuff Panels
Skyline R32 Door Scuff Panels
Skyline R32 Front Guard RH
Skyline R33 Passenger Airbag
Skyline R33 Door Glass LH and RH
Skyline R33 Hicas Unit
Skyline R33 Ashtray
Skyline R33 Rear view Mirror
skyline R33 Fuel Door
“FOR ALL ENQUIRES INBOX ME”
Edited by perry_r33
Needed to upload more pics
https://www.sau.com.au/forums/topic/483152-skyline-r32-r33-parts-bonanza/
Alright. In the absence of prices, I am going to offer $200 for;
Skyline R32 Door Glass (Genuine) RH AND LH Side
Inbox me for prices 📥 as there is a lot of spares listed 👍 and I am unable to edit the post
Edited by perry_r33
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
