A few months ago I purchased an R33 rolling shell and have been working on restoring it. After some bodywork and checks, I've been able to identify it as a 1994 Nissan Skyline R33 GTS-25T Type M, and found out it was imported into Australia back in 2005 by a previous owner. I found the dashboard and gauge cluster were Nismo, and just assumed the previous owner had put them in for some reason. However, I recently discovered that they had made GTS-25T Type Ms in Nismo spec, something I hadn't known before. I want to verify, so does anyone know of any other indenfiers or defining features that can confirm whether or not its a Nismo? Note: No engine, transmission, exhaust, spoiler, or bodykit. All had been removed when I purchased it.
https://www.sau.com.au/forums/topic/483764-identifying-nismo-gts-25t/
On 14/06/2022 at 4:32 PM, Duncan said:
I am reasonably sure there was no "nismo" r33 gtst, what information did you have on such a beast? If you check your vin in FAST it might tell you if there is something special
I'd found these while doing research on the gauge cluster
As others have mentioned it's most likely the Nismo package option.
I do remember many years ago there was a guy on this forum who owned a Nismo optioned gunmetal grey series 1. it was a Nismo pre-production concept car which was set to be a GTS25t equivalent of the 400R. it was pulled from the assembly line and never made it. it was only discovered from official nissan marketing material left in the boot.
On 14/06/2022 at 10:12 PM, dyl33 said:
That nismo wing is filthy.
Well, let's just say it was "period correct". You would have been the coolest person in the carpark under the freeway in 1995
  • Like 2
On 14/06/2022 at 10:23 PM, mlr said:
I new I seen something somewhere
Build this, call it the long lost number 4
So was this so called 2500R actually a thing ? As in did this car infact come from Omori ?
It's maybe plausible in some regards, but the pictures show some pretty obvious modifications that wouldn't have been how Nismo does things. The missing fan shroud is a weird one.
yeah, saw it myself in real life. Was in Sydney many years ago, no idea where it went.
OP, you can search your VIN in gtr-registry.com and see what comes up. But you will find it's a regular GTS25t with some Nismo aftermarket parts (fairly common).
Wow - just read the whole thread on that so called 2500R prototype. I get it is a real car, but it didn't actually go back to Nismo for anything did it ?
What a really, really shit thread to read... so confusing and contradictory on the claims made.
No idea, very good point. It was a good dream though hehe.
Yeah, seems the whole Nismo thing was just a kit. Not too disappointed, still my dream car either way, and the gauge cluster is sweet. I have fallen in love with the idea of a GTS-25T Type M Nismo though, so I might pursue a Nismo-inspired build! Chassis no. is ECR33-017724 if anyone was curious.
  • Like 1
On 15/06/2022 at 5:35 PM, GTSBoy said:
Imagine all that love and attention paid to a car that actually looks good. Like a 32 or a 34?
While I disagree with your implication that the R33 looks bad, perhaps this R34 GTT Nismo kit tickles your fancy? I find the wing particularly beautiful for the car
Oh no. That R34 wing is dreadful. Looks like it belongs on a Honda. The whole back of the kit is bad actually. Only the front is OK.
I belong to the "R33s are boats that look like a Maxima aggressively rear ended a Magna" camp. The profile of the car is poor. The length between the back edge of the door and the rear wheel arch is just too long on a 33. The front is bland in a Magnaesque way and the rear is just f**ked up.
The R32 maintains the correct proportions from the cars that created the look (ie, the early Mustangs, and to an extent the earliest Skylines) that sort of survived in the 70s Skylines but definitely was solidly in the design language of the 80s Skylines. The R32s only blemish is really the front end of the bonnet. But that can be changed.
The R34 brought back the correct profile and proportions. It was actually confrontingly square when it first came out, but that soon passed. The only blemish is the slightly incorrect taillights, but they are much better than the very wrong lights on the 33 (and the lower end and Aussie built 31s). Equal sized stoveplate rear lights are a requirement for a proper Skyline.
You have to slap a lot of tupperware onto a 33 to mask all the problems.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
