Interested in Billet block information in regards to oil setup.
Given how many 4wd rb26 blocks I have seen crack and even one with an engine brace.
The billet block seems like a really good option for a reliable motor you can launch.
I do however want to keep my car very street focused, I want to run AC and I also don't like cutting holes in it.
I have been told that the billet blocks require external oil pumps and so far the only explanation is that the billet blocks need a lot of oil pressure.
The other thing, which is more of an issue is that I was also told they need to be dry sump.
Would be great for someone to explain the need for external oil pump and anyone actually know if you can run wet sump ?
Edited by Butters
  • Like 1
https://www.sau.com.au/forums/topic/483839-billet-blocks-oiling/
You need yo run an external oil pump because they require a lot more flow and pressure because of the main bearing clearances.
hi octane do a single stage pump that fits under the alternator and allows you to keep your aircon and have a wet sump to suit
you will need to make sure you warm the engine up before driving it to allow the bearing clearance to grow
  • Like 2
Thanks.
Just to be clear, the bearing clearances are larger due to billet ?  or due to the power levels people usually chase with these blocks ?
Trying to understand what the difference is here between say an Sr20 cast alloy block.
It's interesting as when I spoke to bullet, they said i could drop my current rotating assembly into the billet block, as it was same same. I guess we didn't get into the specifics of bearing clearance, nor did he mention external oil pump requirement at the time.
Funny enough i was scrolling through a year of PMC's posts looking for info.
Found the one you posted above, thanks you have been very helpful.
here is the video in the above post for anyone else interested
  • Like 2
No worries, I’m literally going through this myself at the moment because I’m having an engine built with a billet block. I’ve decided to with a dry sump setup in mine and have been told by 3 people including the engine builder to make sure I warm it up before driving it
I'm having a engine with a billet block built.  Can use an external pump that sits under alternator and re-use the wet sump and A/C compressor.  If going dry sump needs larger oil pump which sits in the similar location as A/C compressor so can't run A/C.  Unsure if anyone made kit to keep both for dry sump.
Edited by RB335
I’m chasing what ever my turbo will allow, being a 6466 the maximum seems to be around 600kw at the hubs, my goal is very low compared to what most people with billet blocks are chasing but I’ve already cracked one cast block and don’t want to risk having to do it all twice
To be fair you cracked the block while using and blowing a standard head gasket with 25 -30psi of boost, hardly surprising. I've mentioned I've cracked 3 over the years and others haven't, so let's see how long it takes to crack the current one with the 6466 at over 600kw. One more cracked block and I'll entertain the billet block idea possibly.
How long until your cars running with the new bling bling engine block Brett ?
It also ended up with the typical external crack
I’m still waiting for the engine to come back, I shaped the body side of the wiring harness yesterday and I’ve got pretty much every part that I need, I just need an engine to fit it all to
 I am very similar, not wanting a monster, just want something that won't break.    I look at the value now of a good running RB26 and wonder if i am better off selling and building billet before I put a crack in and its junk yard.
I also really likes the idea of dropping 20kg from the car, losing weight in a proper street car is not easy and it all makes a difference.  Not so sure about the weight saving though, now your adding pumps.
The warming the car up is not ideal.  It has me re-thinking a lot.
I only use the car once every couple of months and I spoke to a guy with a billet block in his street car before I made the decision to buy mine and he said 10 minutes and it’s ready to go.
billet blocks transfer a lot more of their heat into the oil compared to cast blocks Which helps gets the clearances up to spec quickly
I would just bite the bullet, go dry sump, put heater into/onto oil tank and pre-heat before driving. Should be possible to use a standalone lithium battery pack + maybe a small inverter to run that heater so you can do it anywhere without drawing stupid power from the starting battery.
On 23/7/2022 at 12:57 PM, joshuaho96 said:
I can't imagine idling a car for 10 minutes any time I want to go somewhere but I'm not really the target audience for a billet block anyways.
I suppose it all has to do with how the car is used. If it’s purely a toy then generally when you use it it’s an “event”. If they’re not a daily driver then who cares. 🤷‍♂️
  • Like 1
    • I dunno about that as a blanket statement. Pitwork is Nissan's "Nissan genuine" thing, and for stuff like timing belts, I have found them to be excellent. Of course, for things like oil filters, you always use proper trusted brands anyway, not whatever the OEM has taken to using.
    • Ahhhh... If you were putting 12V to the led in there, that's likely made it very unhappy. Chances are how you put power, was 12V across an LED that's meant to only have about 20mA through it at peak, and a forward voltage of about 1.8 to 2.4 volts. That circuit is likely only a 3V3 circuit, and will have a resistor in series with the led too. That's my guesstimate on that light, without having touched one.
    • Another vote for installing them and see how you go.  I mean, you already own them, why would you not fit them?
    • I have had too many of those over the years, my cars have a toolkit or at minimum a cheapy multi tool thing because its too easy to be snookered by some stupid plastic clip that stops you checking the battery terminal isn't loose.
    • Basically, if there is a part# on the nissan catalogue, it is a genuine part. There is a thing called "new old stock" which is stuff made years ago but never sold (or landfilled), but it is super hit and miss what you can buy. Other than some expensive Nismo stuff there is nothing new being made that suits these cars. The only time to be a little careful is (mostly in the US I think, but maybe Japan too), Nissan started rebranding some cheap crap maintenance parts like oil filters as "Pitworks"; stay away from them, if you are buying cheap just buy whatever the local car parts shop carries The three part numbers have an explanation on Amayama: 0V005 is auto, base style 0V015 is manual 0V505 is auto, hectic momo branded ones, maximum F&F points there!
