20 hours ago, robbo_rb180 said:
I'd say the biggest issue will be the 2 cheap fans on it that came with the radiator. Ditch them and get the factory clutch fan and shroud on. The cheap stuff doesn't move enough air.
The only electric fans worth putting on are either spal or maradyne. In 14 or 16 inch with proper shroud.
I use cheaper radiators but always use factory fan or the mentioned electric ones with no issues.
Sorted!! F**king loving it! Ditched the twin fan setup for the single 14. Running perfect! Cheers robbo_rb180 because the twin fans were brand new, if you hadn’t mentioned it I wouldn’t have even spared a thought for them being the issue! I know its not the clutch fan setup every one suggests but its a win either way. So cheers to everyone for chiming in, made my year ya bloody legends!!!
  • Like 4
3 hours ago, darkoh69 said:
 as the old saying goes if aint broke dont fix it
Yeah, as in shouldn't have changed the factory stuff there in the first place which is why Dose Pipe said what he said.
  • Like 4
  • Thanks 1
  • Haha 3
Factory stuff broke years ago. All I could get at the time was a 14 inch electric & a cheap Chinese thick alloy radiator which for many years after never let me down which is why I said what I said
Oil temp on track will hit 150C in a lap or two. Or at least it did for me. So yeah, oil cooler pretty mandatory for track fun.
110C is the exact point the needle moves from "middle" to high in a R34. 109C is middle. So there is no 3/4 anything on a 34, but yes this thread is about a R33 so who knows whether that is accurate.
OEM fan is best. Always. Nigh on impossible to break the OEM fans. OEM fan without shroud is still pretty much the 2nd best thing lol.
5 hours ago, darkoh69 said:
Most later model cars run em
Yes, as part of a system that was designed around having that fan. On RB engined cars, the radiator was sized around the air flow that could be pulled by the engine driven fan, which is an enormous number compared to what you can pull with even the best electric fans.
So, your experience is that it works. But when you present it with a challenge, such as idling in a traffic jam at 45°C ambient air T, 50+°C road temperature (which is a common event where I drive mine) then you will likely find that the electric fan version will suffer a lot earlier than the engine fan one will. And that is why there are only a couple of 14" electric fans that people say are acceptable, because these are the only ones that have managed to get close to the performance of the stock setup, with all others found to be not-as-good(TM).
  • Like 4
11 hours ago, Kinkstaah said:
oil temp on track will hit 150C in a lap or two. Or at least it did for me. So yeah, oil cooler pretty mandatory for track fun.
Jesus, that's way too high!
I run a 25 row Setrab core in the driver side guard and I can manage to keep oil sub 130°C doing continuous hot laps (well did, till the engine seized lol).
Should’ve had electric fans engine probably still be spinning 😜
  • Haha 2
Haha actually the motor seized because the sump was sucked dry around a corner and the oil couldn't return to the sump fast enough.
  • Like 2
This was pre-oil cooler on the RB! Post Oil cooler it sat at about 100C ish doing the same kind of hot laps. This was with the cooler in the driver side.
Post change to LS I had the cooler in the passenger side, and noticed it actually cooled better there than in the drivers side. But I moved it back to the driver side due to my intake. Did 70 hot laps at Sandown and water stayed at 87 and oil was happy at about 105.
With thermofansomg (but they are OEM AU ones). Utterly irrelevent to this discussion other than OEM VERY GOOD YES YES.
  • Like 2
No I see relevance in this. It seems like your saying ‘oem very good, but thermos are very good also.’ & ‘In your experience falcon thermos are better’.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
