On 3/22/2023 at 5:54 AM, PonieBoi said:
Rears can tuck 17x9 +30 with stock arms (bought camber arms all round just in case)
20 hours ago, GoHashiriya said:
Looks really nice, good work
Except that it is clearly too low at the rear (and presumably at the front) and will handle like a bucket of puss. The suspension arcs are not supposed to work with the wheel pushed that far up into the well.
If you're going to run it that low then you really should be using different bushes to push the rear subframe up towards the floorpan as far as it will go, and drop spindles. Drop spindles at both ends. The GKTech ones are good, and you will need/want to use their upper and lower arms with them also.
Edited by GTSBoy
Coilovers are how they came out of the box. Only just got the car home today.
Got camber arms for front and back but don't really need them.
Got the car home for the first time in nearly 6 months.
Fresh kit, paint job and wheels.
Next on the list is chucking in a non hicas subframe which I'm in the middle of doing the gktech reenforcement plates on, and also will be looking at new injectors and one of mine has a leak.
  • Like 2
Now that I can go back to working on this thing. Back to trouble shooting.
One of my problems is the car doesn't like to start again after it's hot (hot start). I have to disconnect the fuel pump to starve the motor, reconnect and start.
Got the injectors tested and cleaned, pretty much all above board. Will wack them back in, take the car around to Jaustech (SA), get the hot start config looked at.
What GTSBoy was mentioning has nothing to do with if they fit or not while stationary.
At super low ride heights, the top and bottom arms, along with the tie rods, move into some very odd areas, where as the wheel travels up and down, it will actually start to turn left and right.
Low ride heights, end up with bump steer.
Perfectly fine if you have a show car, but if you want to actually be able to drive down the road and have the car NOT automatically turn left and right unpredictably (with no steering wheel input) then super low height won't work. Camber isn't the only thing you need to worry about...
I know what he meant haha. I've raised the car since then but the moment I got them out the box without adjusting them, that's how they sat.
  • Like 1
  • 1 month later...
Been a minute. Haven't really done much with the car. Just enjoying it.
Pretty much finished my non-hicas subframe.
Figured I'd re-enforce the tabs and mounts before it gets painted.
It's not pretty but for my first time welding, itll do alright haha.
dzvHClmW1EIEbTmayOdmR3dhNmQgbiJgETJkwb6a9lHkPhNIfT_Le6XklAvLcA1Dgah6yAXiyYp56vM6nhmd7wqnGCDX8UO-QXExDGh-T7YBuNUSudVh5x95_ZT9GQR1k1bqRMeyxp-XBhzKlI2gOw1iB7F6tkeZFCrUTniztHB7sF2-Zy31MjgJlL8floVZva_bD43qB4AAQZe3LopSrhFda6fwUW9rNF_CW7FYlvfZNFQ6B3iJfEJAx5zxpQq4kpY5rYJOMS8VvHDMmCEGVXaUFyqLkNpQ6nMM-xCnTULhIShIRJS5IFVkiiRqEkO_5f1ZXzftFGaNf223ATn6bRaIaJFey5LIhoJzZ5V5vnxzFhpZbFXt_p4mMQpdfD4N41tJDgiQqOl3hvKX_RUTemRqpSnl3zBxeMVrqeKAo7zGkkJa_EnVWMNbuAveq0_bl3n0GgldyPRyKRpwnSKPYlKQ5Zibr29njHfL6jTVnJbQivXm05G0EIBV1OJxRdS4lWUOzWMNpr-5p8iK1e_k52aQ6xGonPxpO8D_hiOvQG1Npv3Y-s9p2VVFl8a73LTKIEoTik5hgDpddS3KxDV2A8CoDVSYXWhTCGRD1hO30WmpFzc3-PQyI9igOIQZcxkLmIKkVPSvATLrBRusoc-YrJumY4l_DeeDIyeo8pszwTbt6nhRQEeg72yFJ8cZnzivTPWkT_lECkfzo-VvntwP0EK1ZyqPxwuS3PTlczbqizEVsXtspMarCb1Arg6J0JULaKmtvVhE0UhaHOeuzSJxphWrFHudYt1Cmnew9kNzypnFGhQ_xIxD1B7GL7l1w3KN46Ne6oqvA7Tj5t8ejlNluGWBfdueaE1rj9lcfTwk6CGaICc1YnHlNHZgiZKOVyG4ZcXH6xPhRSYU8cnX4Aqkryq5nBiP-8wVMGdIkTTNK-SmuxnOGQ=w1328-h1000-s-no?authuser=0
Pulled my knob too hard (haha) and shifter bushing became non existent. Went to get a gktech solid bushing from Sleekas and it turns out the bushing has worn that much, I need to get a new/not f**ked shifter.
If anyone has other aftermarket options they have used, hmu.
Turns out there are 2 different sized shifter balls, and therefore 2 different size shifter bushes - noting they might both have the same outer diameter where they go into the gearbox
Looks like R32 sedan is the smaller shifter ball
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
