On 02/02/2024 at 8:05 PM, joshuaho96 said:
You are not removing the oil pump without pulling the engine. Just isn't happening. It is theoretically possible, in practice a 700 pound boat anchor is going to be hanging over your head and the slightest mistake will severely injure you.
I have done very annoying jobs that should require pulling the engine but I didn't. I get the mental block when it comes to pulling engines, especially because it requires a ton of shop space most people don't have. This is one case where you need to pull the engine.
Ok, will it be worth it to put on a fluidampr to prolong the life of the stock pump and gears?
Edited by The Skyline Guy r34
Probably, especially if the stock damper is 25+ years old. I don't think it will do much for the oil pump which mostly dies to cavitation but the rest of the engine will appreciate it.
  • Like 1
I have to add, I've run two(small sample I know) RB26 with stock short nose r32 crank and stock oil pump gears at high power over many years without issue.
I do always put on an ATI damper and manage limiter.
650whp - run 9's and has been in my hands for 16 years and counting.
780whp - driven weekly, roll raced etc and been going 4 years and counting.
This is no guarantee for you but it is a counter to the RB's smash gears by just looking at them :)
  • Like 1
Ok, so you would say its worth getting a damper?
It's always been my policy but I have no comparison motor without one to compare it to.
As others have said, the one on your motor is also for sure trashed by now.
  • Like 1
I will bet if you've never replaced your damper the one on the car is absolutely wrecked and you should think about replacing it regardless of how much power you want to make.
  • Like 1
  • 1 month later...
You should wait to get the billet gears like the guys are saying, but removing oil pump in engine if you ever need to for some reason is possible. I coincidentally just watched this video the other day. I bought gears without knowing how much trouble removing the pump would be so I've decided to just sit on the stock one till it goes and then go down the rabbit hole of pump, gears, crank collar, head drain, pan, etc.
well, good on him for proving its possible, but it is still not how I would do it. That vid doesn't show probably the trickiest bit with cleaning and resealing the sump (although he does state it is done and not leaking, wish I could say that for mine :rofl:)
My view is still that replacing an RB oil pump is an engine out job, and you probably shouldn't do it without putting on a larger sump and doing some oil return mods.  There is very little safety gained by moving to billet gears alone, and you really can't put in a higher flowing one without making other engine out changes. And of course, in a 32 you still have the short oil pump drive which is by far the biggest issue with pumps. Also, the time to do it in the car is almost certainly longer than the time to R&R the engine and doing it on a stand.
Just stay off the limiter with a standard engine. Or really, any engine, these things are expensive these days
  • Like 1
But but but... It's when I know it's time to change gears or reached my desired max speed in 4th (as I'm still using the factory dash lol).
Yeah, I wish my redline in 1st was about 10k. It comes up and yells "Surprise mutherf**ker!" whenever the red mist comes down at the traffic lights.
  • Haha 3
8 hours ago, r32-25t said:
Once you’ve pulled the box, the crossmember. The drive shafts and what ever else, it would have been quicker to just pull the engine
And now you have 500+ pounds of engine hanging basically in free space threatening to split your head open. Not worth the hassle. And I would go as far to suggest that doing turbos with the engine in the car is not the worst idea in the world if you can afford to take your time and don't have space for a car and an engine.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
